Help choosing wheel offset
JCAntimatter
Long Island, NY
19 4Runner TRD PRO, Acura MDX
You could add 1" wheel spacers to the badlands wheels or replace with new wheels with offset similar to sasquatch. You might also want a Zone $60 level kit (raise front 1").
OBX SAS. 1" Zone Level. -10 Wheels.
Ford Bronco Help choosing wheel offset 68DF52AF-69F3-46BD-A182-EF3E98C2AA0B_1_201_a
Ford Bronco Help choosing wheel offset 52EC5AED-2EBD-46BC-BBF8-4112C500373B
Ford Bronco Help choosing wheel offset 93B514EA-8213-446E-8586-36F3E07C9FD9_1_201_a
Ford Bronco Help choosing wheel offset tempImageRvATtz
rtaylor
R
ID
19Raptor, 22Bronco
thanks, thats my main question, WILL small lift allow me to use +55 offset stock wheel, if not then i need new wheels WITH slightly different offset like +30 same as sasquatch, i hoped just small lift, however, a lift doesnt exactly do the same thing as offset on the wheels right? the 55 offset could still rub on the inside?
Correct, the wider tire will likely rub on the suspension parts unless you add a wheel spacer or use different wheels. Most people don't like to use wheel spacers (myself included), but they are cheap.
cpmartin1999
chris
Atlanta
2022 Badlands, 2020 VW Atlas
yea thank you buddy! i wouldnt like spacers, doesnt sound right. was hoping to use stock wheels. Now wondering biggest tire i could fit on stock wheels, being +55 offset im thinking i have no "work around" to get to 35's without new wheels, which is what i was hoping to avoid because of price!
cpmartin1999
chris
Atlanta
i have one final question i figured id ask you rather than create a new post, i look to NEED to do +30 offset to get 315 70-17 tires onto a Non sas Badlands, so, if i cant get someones SAS take off wheels i need to buy new wheels, here is the question, i think it seems i would want hub centric wheels, that seems to me to be way better, i dont want all that 4x4 stress on just the lugs right? so where do i get hub centric wheels for the bronco, or am i overthinking it??? Thanks!
Vigor
Heaven on Earth
Can anyone advise that if I wanted an offset of say half an inch, I can just Instruct my mechanic to do just that?
A little more info. Fitting 33.4 inch tires (275/70) on an OBX with 1 inch lift and 42 offset. Simple as that??
Destroyer
2002 Chevy SWB NBS, 2022 Bronco
Surely you're not asking if your mechanic can just GIVE you half an inch of offset right? Offset has nothing to do with tires, and is measured from wheel width. 42mm offset (I'm assuming positive?) on what width wheel? I'd recommend doing research on your own and figuring out how all this works. Look up how backspace and offset are measured. 15 minutes of your time and you'll figure it out. Here's a pic to get you started.
Ford Bronco Help choosing wheel offset wheel-offset
