Help! Can't find AUX wire behind sunvisor
TLO
Canada
youtube.com
2 door
2026 Bronco...
I have the entire windshield brow trim pulled down on the passenger side.
I can see the taped up harness running across to the center aux switch panel...
But I do not see the AUX wire lead anywhere up there...
Anyone help out?
TLO
TLO
Canada
youtube.com
2 door
Welp, found it...
Wrapped up in hockey tape with a half inch of wire expose, in the A-frame corner, and facing the outside of the Bronco 🤬
After pulling the shrink cap and yanking it out of the tape, here is what I had to work with....
Ford Bronco Help! Can't find AUX wire behind sunvisor 2384
It's not that the wire wasn't long enough, but shifted to have all the slack behind the glove box!
Ford Bronco Help! Can't find AUX wire behind sunvisor 2381
But, I managed to do what I needed to do, bloody knuckles not withstanding...
totaljustice
Kevin
Middle Sackvegas, NS
Lol!!! I was about to tell you that I had the exact same problem and discovery!!!
  • Haha
Reactions: TLO
Species8472
CO
2025 Bronco Badlands Sasquatch
Here's a video on it:
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
2026 Bronco...
Anyone help out?
Honestly unless you are using that to power like a dash cam or something LOW AMPERAGE it's a waste. I DO NOT recommend using that pass-through wire (which is what it's called) to power a roof mounted light bar. It's WAY TOO SMALL to power anything significant. Best to run your line down the outside of the windshield and use a KC Wire Hider
https://www.4x4truckleds.com/kc-hilites-universal-wire-hider
TLO
TLO
Canada
youtube.com
2 door
Thanks...vid not much help.
But I managed to get it all together
I'm actually using it to power a multi USB charging port.
I have a DV8 overhead Molle panel and mount my Sony camera, drone and laptop up there so I can charge while on the go 👍🏻
The circuit is good for 10A (AUX 3) but you can configure it for 30A.
I believe all the pass thru wires are 30A rated (looks like 10AWG).
So long as the conductor length is under 10 ft., it should be fine.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
That wire would not handle 30amps. It's way too small. I don't know why Ford claims it will, but the gauge is too small.
CalvinT
Calvin
Phoenix, AZ
It's not a waste if you're using it to power something that draws less that 20 amps. I'm using it to power my roof mounted light bar which draws 16 amps.
