Hardtop Uneven - Road Noise
Po
Fort Worth
'20 Sierra / '22 Wildtrack / Bronco Raptor ordered
I just took delivery of my Bronco (Wildtrack Sasquatch) with MIC Hardtop on Saturday.
However, I noticed some decent air noise that wasn’t apparent on my earlier test drive with the dealer model. I noticed that the driver side of my hardtop sits about a half inch higher than the passenger side.
I took the tops off and reinstalled them, but they still sit unevenly.
Does anyone else have this issue? Pictures attached.
Ford Bronco Hardtop Uneven - Road Noise 55E2674C-D201-49F2-802C-07FC674ED73D
Ford Bronco Hardtop Uneven - Road Noise 63A92D82-023E-4C06-859C-52B34F522814
Draughon
Daylon
Dallas
BMW 4-Series
Take it back to the dealership - have the warranty fix it.
NC_Pinz
Central NC
2022 Ford Bronco OBX w/ Squatch, 1975 Ford Bronco
Did you try unlatching the driver's side and re-seating it?
honeydoeverything
Po
Fort Worth
I did. I uninstalled both, and put the driver side on first, then the passenger side.
Broncolli
MD
'21 Back Diamond 4 door MIC
Maybe the passenger side is too low ?
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi there! Can you send us a private message with your VIN and Ford dealership name? I’ll look into this on my end. Thank you!
Beach_Bum
St. Augustine, FL
2023 Outerbanks Bronco
That's backwards. To remove, driver's side first then passenger. To install, passenger side first then driver's.
honeydoeverything
Po
Fort Worth
i wrote that one wrong. I took the driver side off first, and I reinstalled the driver side last.
ALVA DUDE
1974 Bronco Ranger
I have the same problem and getting increasingly worse with wind noise. Everything seems to be sitting evenly, but now as the wind noise gets worse, im hearing ALOT of creaking noises.
Ive reached out to Ford to no ado. GO FIGURE.
Glad they responded to you, though! WINNING!
Wish theyd reach out to me!!!
honeydoeverything
Po
Fort Worth
The bracket on my driver’s side is noticably higher than the bracket on the passenger side.
This is why the top can latch, but it’s still higher than the other side.
Ford Bronco Hardtop Uneven - Road Noise 050FBB05-3139-4A1C-9498-74C511C53609
Ford Bronco Hardtop Uneven - Road Noise 2324AC2C-1C3E-48D6-BA39-5BBB7F3CB4CE
Ford Motor Company
Dearborn
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
Bronco71
Scottie
Alabama
1971 Bronco, 1979 F250 Ranger Lariat, 1980 CJ5
It seems I have the same problem. Has yours been solved yet?
honeydoeverything
Po
Fort Worth
it did get fixed. Those brackets are actually slotted and bolted. The plastic housing just pulls down and you/they can access the bolts. Just slide the high side down and bolt it back in.
Ford Motor Company
Dearborn
Good morning, Scottie! Could you please send us a private message with your VIN and dealership information? I would like to look into these road noise concerns for you on my end. Thanks!
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
For the creaking/squeaking/popping noises you can either sleeve the location pins or use a Q-tip and put a dab of lube on them. I just used a food safe silicone lube I had. Went from snap, crackle, pop over every bump to zero squeaks in the last 6 months over multiple trails.
