- Bob
- Dec 13, 2024
- 10
- 95
- 244
- Carbon County, PA
- Bronco
- Raptor
Is MIC an acronym?
Molded-in ColorIs MIC an acronym?
Thanks.Molded-in Color
Is the OEM rack the same for all model years? Also wondering if the OEM rack could eventually cause the same problem on a painted top. I removed mine almost immediately after bringing it home but was thinking of reinstalling it for a planned trip next month.2025 Badlands SAS 4 door with the painted black top. Starting to find out aftermarket roof racks are not compatible with the painted tops. I’m having fittment issues with my TrailRax roof rack. It’s split the rear outside accessory mount at the seam and the mounting brackets do not fit correctly in the accessory mount location. Working with TrailRax to sort the issue out. RCI website says their roof rack is not compatible with the OEM painted hardtops. From RCI when I emailed them: “Unfortunately, the issue with our roof rack on the OEM painted topper is not one that we've been able to make a revision for as of yet. The issue presents itself in a "delamination" of the roof over time from the tension on the adhesive.”
so if you intend on putting a roof rack on a painted hardtop, I’d wait.
Had the MIC top on my OBX painted two years ago (Heritage clone) and I've had zero issues. To be fair though, I never remove the top.Now if one were to sand it down and get it properly painted, would that hold? Or are we dealing with a more of a structural issue here?
