Hard top squeaking in the cold
Victorsen
Vic
Maryland
Ford bronco
Was wondering if this is normal. Just got our first snow and ice and my hardtop has some ice on top. When driving it squeaks constantly, hoping this is normal because of the ice on top. Thin layer of ice. Thanks
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
Yea, that’s pretty normal from my experience.
Each year before winter I’ll clean and lube the seals around the vehicle - and it still squeaks during the drive immediately following an icy snow storm. Sometimes after a Carwash as well.
It normally goes away after a day or two
Bruzer22
CO
1968 Mustang, 2022 Bronco
Also make sure your spare is torqued to spec. A spare just a wee bit not torqued can squeak, too.
USSCajun
‘23 BD, Sas, 2dr
I don’t have snow or ice but cold. It does squeak all the time. I’d say normal.
Dan-O
Dan
Fountain Hills, AZ
Mine started squeaking when weather cooled too. I put a small 1/4” thick piece of foam rubber on front panels alignment pins mounting surface…. fixed problem.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I haven't heard this yet, but I've only been driving mine for 2 years...in Canada! lol
Victorsen
Victorsen
Vic
Maryland
Ford bronco
Thanks, not the spare wheel. The squeaks are above me on the hard top. Pretty annoying and loud, hopefully it will go away once the ice melts.
Victorsen
Victorsen
Vic
Maryland
Ford bronco
thanks could you send me a pic on what you did
Bschurr
NY
Ford Bronco Hard top squeaking in the cold IMG_9053
Dan-O
Dan
Fountain Hills, AZ
Here is a pic of what solved squeaky roof rattle sounding like it’s coming from over outside shoulder???? 1/2” foam rubber and did not pre cut hole for pin, let pin hole itself
Ford Bronco Hard top squeaking in the cold DD7D0584-576A-48F7-A67A-E3C062D8D6EE
Victorsen
Victorsen
Vic
Maryland
Ford bronco
Thank you much appreciated
joeb
Pennsylvania
FJ Cruiser
Yup. Happens in cold weather. I'd say below 35 deg. Or when ice is up there.
Goes away when it warms up
