Hard top removal a beast
Rigsurly
Coral Springs, FL
Ford F150
I have a 23 two door. When I try and remove the drivers side panel I have to beat and punch the area just above the mirror to get it to free up. Some time ago I came across a post about how to align the pin so this doesn't happen. Can someone help me find it. ( I searched using several different terms but was unable to locate it.) I figured I would just take it to a dealer but they told me it is 7-10 day wait for their trim shop after I drop it off.
Thanks in advance for your help
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I'm pretty sure you just loosen up the bracket(s) bolts that the pin drops into and slide/move/adjust the bracket accordingly.
ChrisB351
Shreveport, LA
Theres a TSB for adjusting those attachment points. You can probably find it on google.
Ford Bronco Hard top removal a beast 1712095327107-6y
Trialmx
Jack
Ohio
2022 Bronco
