Hard top issues
Walkman73
Tallahassee,FL
2017 Ford F150 Supercrew FX4 V8
Any one having this Hard top issues ? It looks like the right side mount is bent and the Bronco is only a month old :mad:. We have only taken the front row tops off twice
Ford Bronco Hard top issues Bronco top 1
Ford Bronco Hard top issues Bronco top 2
Ford Bronco Hard top issues Bronco top 3
Ford Bronco Hard top issues Bronco top 4
Ford Bronco Hard top issues Bronco top 5
Ford Bronco Hard top issues Bronco top 6
Ford Bronco Hard top issues Bronco top 7
stonerdoom
chicago
2023 Badlands
I think I see what you are talking about? Does it seem like it's sealing up and snug when you are putting the fasteners down? Any leaks that you are noticing? Any change in noise or wind?
If so, hat in hand and head to the shop for the warranty battle. Or, if you know a good fabricator who might be able to tweak that for you. But then you are opening up a whole new can of worms.
Walkman73
Walkman73
Tallahassee,FL
No noise just yet but it's hard to take it off and put back on
Bruzer22
CO
1968 Mustang, 2022 Bronco
Those strikers can be adjusted, there's a TSB to adjust those due to uneven roof panels/wind noise/etc. TSB22-2288
Ford Bronco Hard top issues F2CE3857-E966-4A51-8741-D38DEABE44D6
Ksjrb03
Tx
F250
This seems to be a common complaint with recent builds. Like previously said, those can be adjusted and their was a TSB about adjusting them. Hard to tell in you pic, but if it is truly bent, might need replacement over adjustment.
ChrisB351
Shreveport, LA
I took mine to the dealer for adjustment on the rear of the front panels. I could feel air coming in from the seal. They did the TSB which brought the front panels down and made my problem worse. When I took it back for them to undo it they again made my problem worse but this time the left panel was binding at the alignment pin and wouldnt come out. This time I said screw it, looked up the tsb instructions, and did it myself. Literally took 10min and I fixed both my problems.
Walkman73
Walkman73
Tallahassee,FL
Any special tools needed ?
BigHoof
PA
Ram 2500
Funny, the factory knows there are issues and sends out a TSB but does nothing to correct their assembly process. Then they wonder how to rein in their spiraling warranty repair costs which are currently in the billions. Gee, I wonder why they are so high. :rolleyes:
