RobWTX
Holy crap, how did I never see this thread before!
That is awesome!!!
White Zombie
jim
North Dakota
22 bronco
OUCH!! That one front strut looks like it took a hell of a hit! I'm building a 79 with 14s on it. You must be running 16s with the wheel travel you mentioned.
I'd be interested in seeing the fab work involved to get the ORIs in the Bronco.
Nice work on that engine too
Fronts are done, along with Braptor arms...16"+ travel front and rear.
Next on the to do list is V8 install.
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
😆 NOPE, that is where I removed cooling fin material for clearance.
Tech Tim
Tim
Wet Side of WA
Jeep JKU
apparently YES you are...I see zero resemblance....the Samurai was NEVER available in a half cab.
it did have 28" tires, and no ground clearance....
might as well said subaru Bratt....lol
We never got them here in the USA, though in Central and South America, you see the LWB Samurais running around with half cabs.
Tech Tim
Tim
Wet Side of WA
Jeep JKU
Harry The Heritage
US
www.bronco6g.com
2025 Azure Gray Heritage Edition Bronco
Adding to this thread...
BRONCO now has 720HP Predator engine installed!
That looks awesome!! The 7.3 Braptor was my favorite Bronco engine swap but this takes the cake! Well done! 😁
Were you able to get all the goat modes working properly?
BigMeatsBronco
BigMeatsBronco
Allan
2021 FE 2 door
Yes all the goat modes work perfectly, and lockers and sway bar disco.... I only have DTC codes for missing exhaust valves still, but those will get turned off with a tuner very soon.
ThunderFlash
Doug
Washington
'24 4-dr WT, '22 2-dr WT, '15 Explorer Sport, '02 F250 SD V-10
BMB, ever seen a Defender 90 in a SWB pickup? I never had. I've seen a few different LWB models, but not a SWB.
Ford Bronco Half Cab Pick-Up Bronco Build! 🪚 1988_land_rover_defender-pic-2969727899448615358-1024x768
PWillette
Parrie
Maine
My previous rig. The thing was a hoot...I miss it.
Ford Bronco Half Cab Pick-Up Bronco Build! 🪚 Snoop & Bronco
ThunderFlash
Doug
Washington
I bet it was. I can't believe I've never seen one...but then again my memory is not what it used to be.
PWillette
Parrie
Maine
Not very common state-side...I imported it from GB. It was diesel to boot. The part I miss the most is it was 100% analog, could fix just about anything with a handful of tools.
2022 Bronco Wildtrak
I can't believe you did that to a first edition! with that being said, it is awesome, and many people out there would've loved to see this half cab as an option!
Mirage
Jason
Huntsville, Alabama
'23 2Dr BL SAS Green/White, '24 2Dr HEL Yellowstone
@BigMeatsBronco Any chance you wanna do the top conversion to my Bronco :)
