"Ground Clearance" measured from?
orion
Jeremy
17' F-250, 17' Explorer
Most likely the bottom of the rear diff housing.
PDiddy
Paul
4Runner
There is more to it than ground clearance. Approach, departure, and break over are what makes a vehicle capable. With 23 degree approach and 25 departure angles, the Forster isn’t getting over much.
My dad has a Forester. He wouldn’t describe it as reliable. His has transmission problems and the engine burns oil like it’s at burning man festival.
Used2jeep
Massachuvian
2007 Crown Vic P71
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
THIS...I’ve. Ever heard of reliability when it comes to Subbie’s and I know you can’t convince STI owners! lol
mdepll
mike
toronto
sorento
Ok. I get it forester is great. Now is the bronco ground clearance bad ??? Is jeep much better ?
mdonathan56
2022 Bronco Bad,2016 Q5 TDI, 2009 Honda Element EX
mdepll
mike
toronto
sorento
But does jeep bury it with ground clearance?
Krisegon
Kris
Ohio
2002 GMC Yukon SLT
Listen I’m not Matt Damon in Good Will Hunting, but 11.5 with 35s, equals 8.5 for the Big Bend.
11.5 with 35s means 10 with 32s. You don't get all 3 inches below the wheel. Am I crazy?
Krisegon
Kris
Ohio
2002 GMC Yukon SLT
Ok now I’m confused!
35-32=3
Tires are centered on wheels, which means 1.5 inches above and below the wheel, when going from 32s to 35s. Only the added 1.5 inches below the wheel adds to clearance. 11.5inch clearance on 35 = 10 inch clearance on 32..
evomind
All sorts of things
I have a feeling they're measuring at the rockers.
