Ground Clearance Difference 2.3L and 2.7L Chassis
Felix808
SRV CA
It would be stronger and safer to fold it over. It would be a welded seam, either fully welded or spot welded, and you wouldn't want to trim back to the weld or it will break. Or, like someone said, lay a piece of metal in the recess and weld it in.
If its metal, I agree with folding it over, but looks like its just composite over mold stuff 🤷‍♂️ especially how it got chewed up like it did. Maybe but this time next year we'll know what shows up on our own Bronco's :rolleyes:
goatman
goatman
Richard
Bakersfield
'22 Badlands 2 dr 2.3L, 2000 Ford F450 PU, 2001 Jeep Cherokee
It's bolted to the frame, but welded to the cross member/trans mount. 😊
Felix808
SRV CA
goatman
goatman
Richard
Bakersfield
Waiting for your solution 😁
Ha!
I'd cut it out, cut the brace off the crossmember, and cut the bracket off the frame. Take a section of 3/16 boxed tubing and weld it to the front edge/side of the crossmember, weld a new bracket on the inside of the frame, and bolt that end to the frame. Basically the same as it is now, just nothing hanging down under the frame or crossmember. 😊
Would have been simple for the Ford engineers to design it that way, thinking along the lines of the theme of off road ground clearance.
Losy
Long Beach, CA
Gen 1 Raptor, GL63, S7
Baja Kits sells some aftermarket parts that looks like it would protect the area in the photo Goatman showed. But of coarse billet Alluminum is $$$.
3:34 in video.
goatman
goatman
Richard
Bakersfield
3:34 in video.
Those are rear lower control arms/rear axle lower links. We're talking about the angled braces that run forward from the trans crossmember to the frame, that hang down a bit and got beat up. Only on the 2.7, they're not on the 2.3.
Lakelife36
Ben
Interior of BC
Those are actually braces for the transmission crossmember between the frame rails. I wasn't aware earlier that they hung 1-1.5" lower than the skid plates, which seems a weird engineering decision.
For now, they'll be fine since they're not load bearing, just providing tortional stability to the transmission mount, which never impacted anything since it sits much higher. In the future, when I do decide to make a change, I'll probably be going to the aftermarket since I've already seen designs that address this issue.
I'm also going to show them to the team at the Off Roadeo next Saturday to let them know about it. It may be something Ford didn't even consider/isn't aware of.
Okay so quick question then - are those specific to the 2.7L engine or are they for the automatic transmission? Have members here looked at 2.3Ls with both transmissions to confirm?
goatman
goatman
Richard
Bakersfield
Good question. It appears that these extra braces are only on the 2.7.
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
It's actually metal, it's just weird looking metal. Kind of yellowish. I'm thinking it's either that new alloy they were bragging about or it's Rearden Metal...
ChrisD
Quick update:
Vaughn Gittin Jr. confirmed that Fun Havers is working on a replacement transmission crossmember that has an integrated skid plate. Figures it will be available before mine rusts out. Haha!
Lakelife36
Ben
Interior of BC
For sure? Have we had positive confirmation that it's not present on auto 2.3s?
Not trying to argue, just trying to make sense of a transmission mount that's not tied to a transmission. Would that be from its position when bolting onto the V6 instead of the I4?
Chuck_Ruck
Chuck
Arizona/Nomadic
F150, Wrangler, Eldorado, Harley, Triumph
Here's me molesting a stock 2.3L big bend at the show & tell back in May(looking at oil change difficulty). I have a 36" waist & a 42" chest, on my back i had maybe half an inch between my self and the bash plate. I have no idea if this helps at all. But its pretty spacious under there compared to my 2006 F150.
Ford Bronco Ground Clearance Difference 2.3L and 2.7L Chassis 20210524_104515
Ford Bronco Ground Clearance Difference 2.3L and 2.7L Chassis 20210524_104627
4xFord
Denver
Quick update:
Thanks for sharing, I'll be near the front of the line when the aftermarket comes up with a solution. My 4 door, 2.7 auto's crossmembers took a beating on it's maiden voyage. I couldn't have been more impressed with the Bronco except for these afterthought crossmembers.
Ford Bronco Ground Clearance Difference 2.3L and 2.7L Chassis PXL_20211206_001309922
Ford Bronco Ground Clearance Difference 2.3L and 2.7L Chassis PXL_20211206_004057262
Tooold
Guy
Here
65 FB, transit awd duel sider, flex 3.5L, BaseManS
Any updates? Does a 2.3 auto have these braces?
dgorsett
colorado
F250, Mustang, Explorer
No, 2.3s do not have them.
