Ground Clearance Difference 2.3L and 2.7L Chassis
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
goatman
goatman
Richard
Bakersfield
'22 Badlands 2 dr 2.3L, 2000 Ford F450 PU, 2001 Jeep Cherokee
Pardon the dirt! I didn't spray underneath it! :)
1. From the front
2. From the center looking toward the front
3. From the center looking toward the rear
4. From the rear (the blue must be a reflection from the flash - there's nothing blue under there)
Cool! Thanks! So, it looks like a skid over the t-case, and one coming back from the front bash plate to protect the sway bar mechanism and trans. The front bash plate comes with the bumper, and they all have the gas tank skid. Anything else?
ChrisD
2021 Ford Bronco Badlands, 2021 Lincoln Corsair
That's pretty much it! :)
rdass623
ron
new orleans
Toyota Tacoma TRD Off Road, Fiat 124 Abarth
looks like you may want to consider some more fabrication of skid plates to save the frame members. i guess maybe a little more recon of these trails may have been in order. some straightening, welding and maybe the application of something like a spray on bed liner might be a good idea...
ChrisD
Those are actually braces for the transmission crossmember between the frame rails. I wasn't aware earlier that they hung 1-1.5" lower than the skid plates, which seems a weird engineering decision.
For now, they'll be fine since they're not load bearing, just providing tortional stability to the transmission mount, which never impacted anything since it sits much higher. In the future, when I do decide to make a change, I'll probably be going to the aftermarket since I've already seen designs that address this issue.
I'm also going to show them to the team at the Off Roadeo next Saturday to let them know about it. It may be something Ford didn't even consider/isn't aware of.
De Brus
De Brus
Washington state
That has to be great news to Ford that there were no development costs for the chassis!
I know! Especially when you're trying to tell us they spent 4-9 billion dollars developing it!
portland_lol
new york
Ford Pinto
i had a running joke with my son for weeks.
i asked him what do you do with a honda civic with a broken or bent skid plate?.
obv punchline was "take it for a drag" much like the punchline to the joke what to you do with a dog with no legs.
everytime i hit a bump or there was very uneven pavement heads would turn it was so loud and sparks would fly.
i lol'd for a couple of weeks until i fixed it.
using the car for flattening the snow, driving back and forth on a gravel driveway has it's pitfalls
BaseSquatch
@NotOJsBronco
Hey, so I got under the Bronco this morning with a tape measure. Those K braces sit at about 10". The skid plates sit up about 11".
My skid plates look almost new. Those brackets took a beating. What a difference 1 inch makes.
Wow! So the 2.3L has at least an inch more ground clearance than the 2.7L? Nice!!
Ford Bronco Ground Clearance Difference 2.3L and 2.7L Chassis 3028B4A2-6CFA-4073-9FA5-7B8AABC1A9E4
Felix808
SRV CA
After seeing these pics of @ChrisD taking his Bronco on a rock crawling trail, and having another conversation about the four different basic Bronco chassis, I thought I'd post and see if we can get some undercarriage pics of 2.3L and 2.7L chassis. My understanding is there are 4 chassis, 2.3 2dr and 4dr, and 2.7 2dr and 4dr. The 2.7 has a K element in the chassis. Can some of you lucky folks who already have your Broncos show some undercarriage pics and tell us what you have?
Here is a pic of the undercarriage after a trail run. This really shouldn't be hard to modify in advance to improve the design, and to protect, but it sure appears that it's something to pay attention to. I think the 2.3's don't have these pieces.
Those pictures looks like it is some kind of composite material molded over the metal braces verse strictly stamped steel. It has that over hanging lip that is at least an inch hanging down. As a rule in sheet metal working bends introduce strength, but I wonder if there is any structural gains with the overhanging edges, if there would be any strength lost in trimming it flush via angle grinder ;) and thus expediting the self clearing nature of this overhang ? At least it would be flat & look cleaner than that mess.:sneaky: Thoughts? :unsure:
goatman
goatman
Richard
Bakersfield
It would be stronger and safer to fold it over. It would be a welded seam, either fully welded or spot welded, and you wouldn't want to trim back to the weld or it will break. Or, like someone said, lay a piece of metal in the recess and weld it in.
Lakelife36
Ben
Interior of BC
I was under the impression that the Bronco platform is the same as the next generation Ranger (2022? 2023?), not the current one. Between the Bronco and Ranger that'll include (at least) three wheelbases.
