5PC24
Pacific NW
2023 Bronco
They look sweet. Here is what I got, plug and play no splicing for anyone interested in these.
OFFROAD GAMERS Spare Tire Brake... https://www.amazon.com/dp/B0BKP1MS3X?ref=ppx_pop_mob_ap_share
The reviews on that page note it doesn't work with the Raptor. Would have been nice if it did for mine.
" I wanted to put this on my Bronco Raptor but the provided harness, which supposedly works for other Bronco trims, is clearly incompatible with the 3rd brake light harness on the Bronco Raptor. "
rblock50
Ryan
Orange County, California
VW, Bronco
Not a ring fan either, looks good though but seems someone could make a 3d plastic housing ( i know people love to create 3 d stuff now on printers ) that would fit in say 2 of the top cutouts of the sas wheel and snap in, and have a led light in them that would be clean looking when not on but functional when braking and still be able to ā€˜snap’ it out when needed to change a spare )
I pieced together something similar to what you are talking about and I am very happy with how it turned out. It’s not a 3D print, but looks nice and clean and is way better than the ugly light I used to have and is out of sight until it turns on.
https://www.bronco6g.com/forum/threads/possible-3rd-brake-light-option.63988/#post-1854407
LSU Jonno
Huntsville, AL
2022 Bronco
Darrell
Darrell
Maryland
2021 Ford Bronco Badlands Sasquatch
I bought one from Oracle last year when I didn't have my Bronco. I keep forgetting to install it. Ok maybe I am a little lazy. Yours looks great now to get off my ass and install it.
Searchdawg
Kentucky
2015 Supercrew Platinum 4x4
What type of light do you have? Sounds like something I would like with the sequential stuff!!
As I stated previously, it doesn’t fit flush against the carrier…the center hole isn’t large enough to go past the curvature of the center hub at the carrier. Sounded cool, being sequential and it was specified for the Bronco, but doesn’t fit and customer service is lacking to put it gently.
Ford Bronco - LED Factory Mart
https://www.ledfactorymart.com/collections/ford-bronco
Bronco Buster Wayne
Wayne
Lima, OH
95 F150
Thanks for the info! That sucks!
vrtical
Doug AI
GSMNP, TN
Fords
FYI I had the same issue with the Oracle unit so I just modified it with a cutting wheel. The braptor wheel center is larger than Jeeps etc.
Aurongel
M.
Austin, TX
2016 Dodge Challenger RT
One of my favorite mods still, I get compliments on it all the time. I kept the original third brake light attached though. I don’t need a reason for some cop to pull me over and stick their big snout into my business. Plus, you can technically* fail an inspection with a spare tire light and OEM delete.
CalvinT
Calvin
Phoenix, AZ
Very unique look. I wonder if it will cause a slower reaction time for the driver following.
Thought process... "Hey that's cool! Oh! He's stopping!"
Tricky Dick
Dick
PNW
www.TD-Distributing.com
raptorusmaximus
raptorusmaximus
Horicon Wisconsin
2012 F-150 Raptor
Fortunately, I don't have to worry about emissions or inspections around here.
1st 75th ranger
jeffrey
nj
Ditched the 3rd brake light and went to a circular one inside the rim from Oracle. It's brighter, cleaner looking and I can actually see whats behind me now !!
love to see in white light also
would be cool to have a s reverse lights when needed
Zato_Richy
richy
Bronco 2 door Manual
I got one that looks similar to yours from LED Factory Mart. It’s the one that has sequential lights and is plug and play. It took a month to receive it. The center hole was not large enough to fit flush against the spare tire mount…not large enough to get past the curvature of the hub/camera mount where it meets the carrier; therefore, you can’t bolt the spare back up. It was specified for a Bronco. I have a Badlands Sasquatch. Customer support isn’t so great. They never answer their phone or return calls. They do eventually respond to emails. Been dealing with this via email for weeks and still don’t have resolution.
I wish I had seen your post before ordering from LED Factory Mart. Everything you said is exactly what I'm going through with them.
