GOAT Modes
Poppavein
Redmond, WA
Harleys, Ducatis, 2024 Bronco
How do you know if TC is turned off?
I usually run in Sport mode and I felt like TC wasn’t engaging.
Perhaps the chart is right.
GoHawks63
George
Metro Detroit
2024 Bronco Wildtrak, Cadillac CTS-V Coupe, Roush Stage 3 Mustang convertible
The light signifying TC is off will illuminate on the dash.
Ducati1098
Traction control is on by default in sport mode. You’d have to manually turn it off
Oilbrnr
Scottsdale, AZ
'97 factory locked LX450, '16 Power Wagon w/FWC, '25 Bad/Sas/7MT
Wish you could disconnect the front swaybar regardless of 4HI or LO. I'd be good with a 30mph limit. I put an aftermarket mod in my Power Wagon, so nice to be able to do it and the lockers whenever I want, regardless of the transfer case or speed.
Are you saying that 2 Low and 4A Low are available to me if I add Sport mode? That would take Forscan, right?
No.
He’s saying you can switch the transfer case to other configurations while in a goat mode, but you can’t add configurations that don’t exist
Like going from 4A to 2H in Sport just requires you to select 2H after going into Sport.
But 2Lo and 4ALo don’t exist anywhere in any fashion that I’m aware of that can just be added via software
DarthLincoln
Chuck
Northern California - Contra Costa County
1999 BMW M coupe, 2023 Ford Bronco Badlands 2dr
I believe you can in Normal and Baja modes on my Badlands.
While 2H is available in Normal and Baja, the front sway bar can only be disconnected when in 4H or 4L. There is no GOAT mode that allows sway bar disconnect in 2H.
