GMRS Antenna Mounting Locations?
Thatchman
Xenu
Bronco Badlands Sasquatch
I own a '24 Bronco 4-door Badlands SAS, with a TrailRax Aluminum roof rack installed. I have three questions regarding mounting a GMRS antenna:
1) Best type of antenna for backcountry use (western states)?
2) Best location for mounting antenna given my setup?
3) Best antenna for quick removal when I drive into bad parts of town?
Ford Bronco GMRS Antenna Mounting Locations? IMG_0552
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Shrek27
Fullerton CA
I'm using a 15W Midland and 3db ghost antenna mounted inside on my PVO Traction Board Brackets...can hear and transmit front to back on group rides of 20-25 vehicles pretty spread out trying not to eat dust.
Any antenna with an NMO mounting can be taken off as needed and caps are available to protect threads. I think the most time consuming installs are to the tailgate. Anything mounted on the hood side can easily be pushed through the firewall plug.
projectbadlands
Robert
Los Angeles
2018 Colorado ZR2
Comet Antennas have a sleeve that slides up and is able to flex the antenna down and out of the way.
Figmo
Figmo
Frenchtown, MT USA
Suzuki Samurai, Bronco 2Dr WT, Gladiator Rubicon
From my thread here: My GMRS Solution
First, antenna mount: I figured, ā€œwhy spend a bunch of money for a piece of metal, a couple of holes and some company’s logo plastered all over it?ā€. Instead, I just took a scrap piece of square tubing I had laying around, cut off about an inch and half, drilled a hole all the way through it. Couple coats of paint and done. Bottom hole is where the screw on the cowling next to the radio antenna holds it in place. Top hole is for a 3/8ā€ antenna mount. I’ve got a ghost antenna but this would work for any type of antenna.
DaddyO
Jules
Austin, Texas
2024 Bronco 4D 2.7L Sasquatch
BNBad
Brett
St. Louis, Missouri
F250
I know it will reduce the range, but I also don’t like the outside mounts.
Ford Bronco GMRS Antenna Mounting Locations? IMG_0339
HighVelocity
Big Sky Country
Pinto
That's pretty much what I did, but I just used a mag mount.
It also makes cabling much easier, as you don't need to route the cable outside.
I'm not looking for ALL the fars and swrs and trying to be a radio nerd. I just need something to commuicate with other nearby vehicles. The interior fat, stubby antenna has proven to be more than capable and it's always out of the way.
Oldhippie
Barry
Santa Cruz, Calif.
BMW X1, ā€˜1928 model A, ā€œ23 Bronco
Ford Bronco GMRS Antenna Mounting Locations? IMG_3969
I just bent up a piece of scrap strap and drilled a couple holes…works good enough for what I need…
