Garage width
AJKitebrder40
Adam
Charleston, SC
'23 Bronco Badlands 2D SAS, Eruption Green (Sold), '25 Toyota Tacoma TRD Off Roa
Badlands width is 86.2" with mirrors, my garage is roughly 90" that's pretty tight. I have to park it in the garage, I go with no top half the year, so that's a requirement. JL fits no issue, anyone with a similar issue where it's pretty tight? I'm guessing pulling in a mirror will help for 2 or 3 extra inches (one side).
Just checking all angles.
Mikey1287
22 Bronco, 72 Mach, 03 Mach, 69 Mach, 08 Harley
Mine is about the same. You get used to it. I like to back in when I get home in the evenings so that I can pull straight out in the morning leaving for work (in the dark).
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
My garage is approx 92” wide with a 90° required turn to wedge her in. Our driveway is atypical. It’s tight but doable. Still getting used to it, hanging my head out the window to spot. Good luck!
AJKitebrder40
AJKitebrder40
Adam
Charleston, SC
Mirror folded or no? Ha, I only back in when I'm using my ratchet straps to take off the top (1-2x a year)
AJKitebrder40
AJKitebrder40
Adam
Charleston, SC
Woah, no turns, just straight in.
Mikey1287
Nope. Mirrors in their normal positions. Seems I have maybe 2" on either side. I just go slow . lol.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Ha ha ha. Actually it’s two 90° turns…that really end up being a three point or more to get straight. Ice helps b/c I can slide a bit with throttle and kick the back end around. Plus my Bronco is a 2Door, it would be doable with a 4Door but images of Austin Powers come to mind. 🤪
myrealname123
Trent
Monterey, CA
'25 Bronco Badlands
Curious how y'all ended up with those custom size doors (90", 92") and not a standard 96"? Mine is 96" and that's about perfect, I'd definitely be nervous with 90"!
AJKitebrder40
AJKitebrder40
Adam
Charleston, SC
It juts in at the frame, the door itself is wider, it's just the frame on the outside (it's 2 singles with a support beam in the middle).
AJKitebrder40
AJKitebrder40
Adam
Charleston, SC
I can confirm on this one - pull driver's side mirror in to pull in, with it out.......not so much. I can get away with the single mirror pulled in, just park closer on that side.
