Bronco "width" question.
Newbie
Miami
Sneakers
How many inches in width with the mirrors unfolded?
Am I incorrect in assuming that the Wildtrack is wider than the "base" bronco?
kodiakisland
Arkansas
Specs are with the mirrors folded (which are stickied at the top of the forum), but, does it have the same mirrors as every other trim? If so, mirrors unfolded should be same width as other trims.
Major_Bullsteak
Alabama
Chevy ZR2 Bison, JK Wrangler
Width (with mirrors folded)
Base/Big Bend 75.9/ 75.9
Wildtrak 79.3/ 79.3
Badlands 76.3/ 76.3
Toccoa
Isuzu Rodeo Sport
HankG13
Hank
Phoenix, AZ
2019 Ram 1500, 2017 Subaru WRX, 1990 Mustang LX
Exterior Dimensions (Projected)2-Door4-Door
Drive system4x44x4
Wheelbase (in.)100.4116.1
Length (in.)173.7189.4
Vehicle height 71.9 (base hard top)73.0 (base soft top)
Vehicle width with mirrors (in.)86.2 (base)86.2 (base)
Vehicle width without mirrors (in.)75.9 (base)75.9 (base)
Vehicle width with mirrors folded (in.)75.9 (base)75.9 (base)
Track, front (in.)65 (base)65 (base)
Track, rear (in.)65 (base)65 (base)
The only thing Different with the Wildtrack is having the SAS package as Standard. with that said, manufactures won't extend any set of wheels past fender flares and those will be narrower than the mirrors when they are out.
You can expect the track (how wide the vehicle is [mirrors not included]) to be around 5 inches wider with the SAS package due to bigger tires and different wheels\offsets.
Hope that helps
kodiakisland
Arkansas
Fuzion2Bronco
Asher
New England
Base Sasquatch
GetBucked
Daniel
2014 Focus ST
I could be wrong here... but I'm about 98% sure that all of the bodies and mirrors are the same. They will all be the same width (82.6") with the mirrors out. Where they vary in width with the mirrors in would be the track width. The bigger tires on the Sasquatch (standard on Wildtrak) make give it a wider wheel base. Since width is measuring the widest possible part of the vehicle, thats where these numbers differ from Wildtrak to any other non-squatch package.
Newbie
Newbie
Miami
Sneakers
Than you for all the info guys.
jimmycarter
Boston
328xi
Just checked, should fit in the garage with at least 2 or 3 c-hairs to spare on either side.
Mark T
Little Rock
2017 Honda Ridgeline
Drive system4x44x4
Vehicle height71.9 (base hard top)73.0 (base soft top)
Hope that helps
So if the track is 65 inches, and the vehicle width is 76, does that mean the fenders account for 11" (5.5 on each side)?
Mark T
Little Rock
