Gap on front axle
joshgonztx
Joshua
Dallas
2021 2.7 Bronco, 2010 Mustang, 2019 Audi S4
Hey is this normal.
Ford Bronco Gap on front axle 80A63044-19A0-41C1-9CE7-795CF767DF37
Ford Bronco Gap on front axle 318BC3FD-F53C-43EB-AAC8-2406561CEDD1
‘21OBX
90Bronco19
2022 bronco outer banks
I believe there is a bushing there and the bolt is tightened to the middle of that bushing. Can you spin the washer? If it’s loose it’s definitely not right lol. I vaguely remember having the same thought when I changed my oil and looked around.
Donkeygyrl
Sheri
San Francisco
Bronco on order
Is that washer loose ,should there be rubber in there I'll go look at mine later👍
joshgonztx
joshgonztx
Joshua
Dallas
I am installing a lift kit and was like whats
This gap. It’s pretty tight.
Ford Bronco Gap on front axle imag
Deleted member 3063
Guest
if thats a rubber bushing in there you don't want the washer tight. defeats the purpose
mpeugeot
joshgonztx
joshgonztx
Joshua
Dallas
Thanks for checking ?
‘21OBX
90Bronco19
Washer is tight to the metal center rubber just isolates the axle housing.
0ne
Nate
CO
Flex
Does the front axle/diff have some accommodation for a little up and down movement? Is that why the factory metal engine skid has that big hole right under the diff? My aftermarket skid has no hole or accommodation for up and down diff movement…🤔
dgorsett
colorado
F250, Mustang, Explorer
Good question. Always wonder why they left a hole under the lowest, most important thing. Some aftermarket have them too.
0ne
Nate
CO
Flex
Maybe to tuck up tighter for a better ground clearance measurement though getting hung up on the hole while simultaneously whacking the diff doesn’t sound too great.
joshgonztx
joshgonztx
Joshua
Dallas
Thanks everyone for checking On the gap.
Haha anyone want a 2inch daystar kit $40 bucks if your in Texas area, made my 34s look tiny.
mpeugeot
You just need to step up to 37's ;)
I have 33.5" tires and even they left the wheel well looking a bit open after throwing the Badlands shocks and springs in. That is only a 0.6" lift.
Ford Bronco Gap on front axle IMG_20220910_181104
mwdsonny
SC
2021 BL bronco 4 door Cyber Orange (School Bus Yellow)
does anyone know the pitch of the bolt in question? I over ugga dugga'd when i installed my lift. I have a bolt with washer and nut as a stop gap, but want to install a thread repair but need to know it its 10x1.25 or 10x1.5 I know the diameter but not the pitch.
