Full Range to rear speakers
zuke
Stafford VA
It doesn't have to be that complex, All I Did with my system was hookup an amp and subwoofer to the rear channel speaker wires, Then play some test tones from here;
https://www.demolandia.net/speaker-test/tones/page-1.html
The 40hz test tone easily made it clear that all the crap people keep talking about with 727-01-01, and JBL Firmware programming are unnecessary.
Play the 40hz test tone with default settings, and you'll get silence from the subwoofer. Change one setting;
ACM 727-01-02 '0901' to '0900',
You'll hear the test tone clearly, It doesn't get any simpler or sure than that...
ACM 727-01-01 is for setting the types of speakers connected, and how to treat them as far as are they amplified by the vehicle or not, and while that could certainly be valuable in fine tuning what components are ultimately used, If the question is how to get full range to the rear speakers 727-01-02 is the only setting that needs to be changed.
Further thought, A lot of people are probably trying these settings after just changing the rear speakers... If all you do is throw a set of 4" Kickers back there, and enable full range, the change will be there, but it will be very subtle, and many people wouldn't even be able to hear a difference, (I couldn't, unless sitting in the backseat)
4" speakers without any additional amplification are not going to be enough to make an appreciable difference in the sound.
da_jokker
Jeep Wrangler JKUR
ACM 727-01-02 '0900' to '0901',
You know I didn't even think of that. In my head I keep picturing people sitting there with some app running on their phone trying to read some data etc.... Something that isn't accurate or very scientific.
Watching a speaker to see if it moves at very specific known frequencies is a pretty accurate approach to me... Provided your amp hasn't been adjusted for any sort of crossover filter.
zuke
Stafford VA
I need to make one small disclaimer, I may have the numbers backwards for ACM 727-01-02..
Everything I'm reading when I go back and look says that 0901 is the default, and 0900 is the fix... I'll double check what I have in there tonight to confirm, and edit my posts.
But the principle is the same, flip the value back and forth between 01 and 00, and you should be able to hear when a 40hz tone is getting through.
The amp I was using was set for a crossover of 120hz (LPF), If you can do that you actually should, to be sure no noise from a power line is bleeding off into your speaker wires, and to mitigate any rolloff from the amp. That's just for the test. Ultimately you'll want to adjust that crossover to acheive what sounds best to you. Lots of people lose sight of that, and build their sound systems to the best "spec". It's a system for YOUR entertainment, if the end result in sound pleases you, that's what's important.
Edit; I Did go back, and the correct numbers for a 2021 are 901 for default, and 900 for full range, other years could vary.
OBXSquatch21
Nick
Kansas City MO
Toyota Camry
If I am using an AMP and DSP would it be worth going to my dealer and having them do the flash for the JBL soundbar to send full range before getting my aftermarket stuff installed or no?
BWepps
Huntley, IL USA
2022 Ford Bronco Outer Banks
I ned to make one small disclaimer, I may have the numbers backwards for ACM 727-01-02..
I'll be waiting to "hear" your results! (y)
da_jokker
Jeep Wrangler JKUR
I hadn't been keeping up on this, but I thought they couldn't do it for 2022 models...or was it that you actually needed the sound bar present.. I don't remember.
kevin.gt
Kevin
Canton, GA
forscan v2.3.48 posted on their site is able to write the 3800 and 0900 values on my ‘22 and they’re working for me
MOBRONCO
MO
There was an update to the dealers software that fixed that.
zuke
Stafford VA
Alrighty, so hopefully this will settle the debate, and provide a repeatable experiment for everyone to use to determine if they have full range to the rear speakers...
My setup is using Rockford Fosgate R14X2 in the dash, Stock Speakers in the kick panels,
In the back I have Rockville RWB65B Wakeboard Speakers being driven by a Kenwood KAC-314
And for Subs I have a custom box made by Elevated Evolutions Custom Enclosures with Dual Skar 10" Subs Driven by a Skar M-5001D Amp. I love this enclosure, Chris made it specifically to my specifications/dimensions, and put in extra bracing so I could carry all my recovery gear and tools on top of it...
Ford Bronco Full Range to rear speakers PXL_20220903_144758764
Check him out and tell him I sent you if you want an awesome enclosure that can shake your bronco.
Both amps are set to where I normally have them, with no filters turned on on the Kenwood, and the Skar is set with a Low Pass Filter at roughly 160 Hertz.
The videos were made using a 40Hz test tone downloaded from Demolandia and played via Bluetooth from my Pixel5a. All ACM Settings except 727-01-02 are at default, and the factory head unit is set to default tone settings with the volume at 18.
This first video is with 727-01-02 at the default 0901
Not full range
The second video is with 727-01-02 set to 0900, and it definitely shows that the Bronco now has full range to the rear speakers.
Full Range
While there might still be a difference with different years, anyone can use this same method to repeat the experiment, and find the right setting.
fallguy
Tennessee
2020 Defender, 2022 Outerbanks SAS, 1968 Mustang
Does this mean that I can take my 22 to my dealership and ask them to flash it, even it not putting in the sound bar?
Edit, I got forscan and did these edits. I am on a 2022. New kickers for rear come in today, really hoping they do better than the stock, and sound like the front that I have replaced already.
Mikey D
Ormond Beach, FL
www.mikedelninno.com
2005 Ford Explorer
Hmmmmmm now I wonder if I can get my dealership to do this for me without the sound bar. Has anyone tried that yet and been told one way or another?
Got a text in to dealer. Let's see.
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
Did it work for you?
fallguy
Tennessee
Yes it appear to have. I have to adjust the volume a bit towards the back to get equal sounding between front and rears. I guess about 60% to the back. Putting it right in the middle has the rears a bit lower. At 60ish they both sound pretty equal and much better.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
Oh, I should try that. I like the sound after the upgrades - but it’s front heavy.
