Full Range to rear speakers
F OR D
BD Green Machine
Yes, make the recommended changes and ignore everything "F OR D" is saying that it doesn't work.
It indeed does. I tested it with various audio test tones. There's also video evidence that has been uploaded here.
I forscanned it before I added a key and I would say it was slightly better at best. I wouldn't go out of my way to do it.
After the key install there is no difference. Tried it stock and with the change. I did leave the change on because I didn't see a reason not to at that point.
There are a ton of other people that had the same experience. IMO if you have a forscan play around and see what you like. What I will tell you is it isn't night and day, and not something that is going to fix the issue.
Jlwson29
Jennifer
Sapulpa
One other thing I did differently from the recommended installation, is I flipped the sound bar upside down, so that it's on top of the mounting bar. It just fits under the roof that way, and does not in any way obscure the driver's vision out the rear window. Yes - I'm sure the sound quality is slightly compromised - but not enough for me to really care or notice.
Do you have a pic of that?
Buc N Bronco
Cleveland, Ohio
21 Broncos Sport,2000 Jeep TJ,Mustang pro stteet
Well , I’ve read a lot about rear speaker
Being lack luster
( they suck)
Speaker is low quality and can’t handle bass well
That’s why Ford underpowered them
They should have put larger better quality speakers in the rear
My initial thoughts Ford purposely set the head unit that way
seen lots of ways to try to get more out of rear channels
Read about JBL sound bar
The unit doesn’t impress me
But the business of flashing the ACM module got my attention
Another member (Flip) mentioned it
Asked my selling dealer’s service writer about
He looked at me like I was nuts
Told me to take it to a stereo shop
WTF!!
Tried a different dealer (closer to me)
Which I didn’t buy from (horrible sales mgr)
Talked to there service writer
Explained what I wanted to do
He told me they put in several of the JBL sound bars @$1000
And customers weren’t happy with them
But I said I just wanted him to flash the ACM module
He said ok let’s see what it does
Had it done this morning
And
Wow! I’ve actually have full power to rear speakers!!
No you can’t crank them up over 15-16 on volume
But that’s all about to get changed
Now with full signal I’ll run my Rockford Fosgate 4 channel amp
Replace all speakers (Rockford Fosgate)
And run my powered sub
Best part he didn’t charge me!!
Said it was an experiment
And works
Told him I’ll be back for my vehicles maintenance
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
Wonder if this would work for a 2022… and if the local dealer would do it.
da_jokker
Jeep Wrangler JKUR
Being lack luster
( they suck)
WTF!!
And
And works
I thought it was established that you can't flash for the sound bar unless you actually install the sound bar... Something about the process pairing up or something.
Did they have one just lying around that they used or something?
What the group of people that have worked on this, I'm surprised if flashing fixes it, the people haven't figured out how to hack it.
Buc N Bronco
Cleveland, Ohio
Yes, mine is a 22 basequatch. Standard radio
From what I’ve heard won’t work on the B&O system
and no I didn’t have anything but the stock
Crappy speakers
told the writer I was adding a sub in rear and needed full signal to rear
All I know is it HAS WAY BETTER SOUND NOW!
Speakers are still junk, you ain’t gonna crank it up without distortion
Anything over 15-16 on volume they’ll crackle
Before flash I couldn’t even hear the rear speakers
Now I actually have separation of front and rear
I don’t know what other’s have experienced
All I know is I’m extremely happy with the results !
like I mentioned earlier I’m changing all speakers and adding 2 amps and a sub
My biggest issue was not having full signal in rear. Which is needed for my 4 channel amp
I now will still have front/ rear balance
And a full signal to power sub/ from rear channel. Instead of tapping front
I won’t know results till I get several days good weather to rip things apart
I live in the north/still freeze your ass off weather
And have to work outside
Garage is full/Bronco too tall to clear door
I’ll post results/ when completed
Jhlebica18
Jon
NH
2023 Bronco, 2023 F350 Tremor, 2012 Raptor
So I have a question for all you that are familiar with forscan. I have read multiple threads. I want to do 6.5 rear pods so I want full range on a my23 obx. So what I’m seeing here is to change line 1 to 3800 for the first box. I’ve seen on other threads with the 23 6 speaker system having lost the sub and amp. To get the amp from the fusion and get a 2 ohm dual voice coil sub to go in the factory enclosure. In that thread is says to right line one box 2 to 16F1 to turn power on for the amp. So if I write 727-01-01 3800 16F1 xxxx it will give rear pods the full range and have the amp turn on if I am understanding this correctly. Thanks for the help
Btilly7
Bryan
Woodstock Canada
Bronco Sasquatch, Mustang Mach-e GT
I called my service department and the advisor I spoke to had zero clue about flashing for sound bar. Maybe he’s playing stupid because they want you to buy the sound bar? I’ll try another local dealership
wcmaness
I had the soundbar installed at the dealer and they said they flashed it but it still sounds like a tin can, zero lows, did the dealership miss something?
BBBronco
Johnny
ATX
2021 Bronco Sport
wcmaness
I never did get it flashed. I tapped a LOC into front speakers and now have the rollbar speakers and additional pair of 6.5” speakers in the rear on an amplifier. Also added powered sub to tailgate. Full front fade on the head unit, I adjusted output on LOC to get just a little rear bias
Shawnj73
Shawn
Phoenix
Stupid comes in all shapes and forms, I’d say you know little about audio performance! lol
The B&O Bronco system is Garbage, period! I am also one of the suckers that purchased it. The worst stock sound system I have ever had in a new vehicle dating all the way back to my 89 5.0. More recently, I thought our Tesla S sound system lacked luster for the price of the ride., The Bronco is a ride that could cost north of 60K, and yes, I get it is a noisy off-roading ride, but for the money you pay I would expect a better system than what is in the Bronco. Ford could have added a door speaker and tweeter to the front doors to set up a better sound stage.. I am tired of Ford people saying this was because the doors are removable. Please, the doors already have a quick disconnect connector for the windows and locks, Ford could have easily added a few pins to the connector for speaker wires for door speakers and have the DSP default to dash speakers when doors were removed. It would have added maybe 5lbs to the front doors. Just Fords way of saving production money, If you want to see cheap macifacturing, remove a door panel, or look at the top. This vehicle was albout the lowst cost to manufacture. Shame on Ford. I do like ours so far, however there were a lot of corners cut to produce these vehicle, and the sound system was one. I can honestly say that the tech in this vehicle does not warrant people paying 60K for a loaded Bronco. So to sum up what I am saying, if this system sounds good to you, that is awesome, however I would probably recommend a hearing check up, you may have some tone deafness starting.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I keep repeating myself, but at the end of the day it’s a $30k vehicle that does not have $40k worth of upgrades for the higher trim packages (interior wise). If I was gonna spend $70k+ on a vehicle, it wouldn’t be a Bronco.
My wife’s Ranger Lariat has a B&O system and it kicks for a stock stereo compared to the Bronco version. Super happy with that purchase - but, again only $35k.
CarGuy
New Jersey
2023 Ford Bronco
All the car companies charge for “upgraded” components. My MB has the Burmester audio that cost $5k…it does sound very good.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I just got my Bronco back from the body shop, I’ve been driving a Taco TRD Sport for the last 8 weeks…man did I miss my B&O sound system, what a night and day difference I guess it’s all perspective! lol
Shawnj73
Shawn
Phoenix
I must agree with you on Toyota's... Toyota has not figured out sound/tech period. However, a Takoma TRD is 40K, and they do not charge $1,500 for their upgraded sound system either.
Me personally, If I had it all to do over, I would buy the cheapest non Sausquash package I could buy, with front and rear lockers. Everything else I would do myself. I would have added my own sound system. Not over the top, but clean. I would have traded all my GOAT modes, for a much more capable rig setting on 37'" Ridgegapplers, rolling on a long travel kit from Baja Kits, finished with a beautiful set of King coilovers. If that was not enough, I would upgrade the interior, and get a nice set of custom leather Katzkin seat covers and dynomat the entire rig. A person with some tools and little know how could do all of the listed upgrades cheaper than a fully loaded Wildtrac. At the end, you would have custom ride that outperforms the stock Bronco for around the same price. Just my opinion.
Getting back on topic, I still cannot see how anyone could honestly like the B&O system. It is garbage. Save your money, do it yourself, and I believe that 99% of Bronco owners will be much happier with the sound quality. B&O system is garbage period, and the soundstage design is awful in the Bronco no matter what package you have. Take it from someone who knows, because I feel dumb that I bought into all of Fords sales hype, paid for it, and now slowly getting rid of it all. PS: this is not a good vehicle to have if sound is your highest priority. 😉
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
I don't want to sound like a dick, but I did spend a good amount of time as an audio engineer and set my tone/balance and love it. I agree that it's not the end all, be all system, but the sound is definitely full.
I have an Alpine 5 Channel amp and 8" JL sub ready to go when I feel the urge, it's just the urge hasn't happened yet, over 2 years and counting! lol
Quality of sound has very little to do with volume, but you will know the quality when turned up...
