- Joined
- Jul 19, 2020
- Threads
- 41
- Messages
- 3,265
- Reaction score
- 12,356
- Location
- Northwest Arkansas
- Vehicle(s)
- Ford Bronco, BMW R1150 GS
- Your Bronco Model
- Badlands
what torque wrench? The tiny ratchet and 13mm that’s in your bronco kit it more than enough.
There is a recommended torque spec for the door bolts: 22 lb-ft (30 Nm). That torque can be easily achieved by hand with the ratchet and socket in the tool kit, but it will likely be undertorqued by most if done by “feel” (i.e., the spec is higher than you might expect by feel alone) or overtorqued by some who crank down hard on everything.What torque wrench are you refering too? Theres only a need for 2 socket bolts to be removed from hinge, very easy.
