Front license plate mount
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
jrollo7
James
NY
Range Rover Sport
broncorik
Understand but it requires drilling holes with a capable bumper which I don’t want. Thanks.
I think the stonsho setup is the most desirable...it allows removal of the plate when you feel like it, and it bolts on. Even for those of us who go with a winch bumper can use the kit for the fairlead mount. Additionally, I confirmed after I called the owner of the company today that they sell different length mounts so that I will be able to add the fairlead setup to my Mountains 2 Metal camera relocation bracket. I found that the M2M set up is one of the few if not the only camera relocation bracket out there that has a 90° bracket which the stonsho we'll bolt to directly. That will give me the opportunity to remove the plate whenever I feel like it and use the relocated camera. Score!
SillyPosition
Silly
Israel
None
stonshoseems great solution,
How do you guys handle with the drilled holes from the original placement of the front license plate? I have those two nasty holes...gotta hide/seal them somehow.
broncorik
I patched mine with plastic repair from behind the panel and color matched with touch up paint.
dingle87
Reese
West Suburbs of Chicago
2019 Ford Explorer XLT
I agree. I just couldn't stomach dropping $100 on it. I went with the forum member option who has been posting up his product here. @HBTFD makes a great product.
If I was off-roading more often (or at all right now), I'd probably go with the stonsho for ease of removal while on the trail. Unfortunately, our life is full of kid activities at the moment, so it'll be a bit before we get out into the wild.
MNBronc
Lutsen MN
2022 Bronco
Broncotrax
NORCO
69 Bronco, '17 Superduity, '22 Badsquatch, CR 250R
Could someone post a pic of this? Not sure the best way to do it & my state requires it. Thx!!!
Pinch your plate between the bumper and fairlead. whenever out doing serious wheeling, simply remove the plate for the day.
Ford Bronco Front license plate mount Bronco wra
Trialmx
Jack
Ohio
2022 Bronco
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Our license plate bracket is the original design that you see all these chinese companies knocking off. However ours is made here in the USA out of aluminum and powder coated black. We also include black stainless steel hardware for your plate frame.
Help Support USA Made Products!
Bolts right onto the bottom and easy to remove if you have concerns of hitting the plate while off-roading. Just check out all the reviews on our site
https://www.4x4truckleds.com/kr-off-road-license-plate-bracket-for-2021-ford-bronco/
Ford Bronco Front license plate mount 314561354_10222217122992435_4787890018142567824_n
Ford Bronco Front license plate mount 314610692_10222217123592450_8689005172973035179_n
Ford Bronco Front license plate mount 314624952_10222217122712428_5007118564330016920_n
Ford Bronco Front license plate mount 1697290563139
