Front license plate mount options?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Boston182
San Francisco, California
Harley Davidson Sportster
BaseBD
Missouri
2021 4D Black Diamond
Boston182
@Boston182 I have a picture in this thread with mine mounted like that. Works slicks.
Found a flip up on Amazon to attach to Bronco Bolts above the tow shackle.
Found it! Looking good!
First... link?
Second, do you think the hinge would swivel inward/down or just outward/up? And do you think it'd sit/fit where this guy has it without drilling additional holes? Because I'm about to just copy him and say fuck it.
If you go a Mod bumper and 3/8" drill bit, you've got a free mount. I mounted mine like this. Also, just gave it a slight bend for more "visibility"? First time I've run a front plate in more then a decade so my thought is better then nothing haha
RyanP
Ryan
Maryland
Mazda CX-9
Chester, NJ
Lotus Elise
For those of you without ACC, here's an alternative under 5 bucks. I mounted 2 stainless steel L brackets on the inside opening (top of inside opening, L's facing up). I used 2 small self tapping screws (1 per bracket) with the holes underneath so they're not visible. There is a thick wrapped cord (possibly wiring) in that area but they popped right out. You can tuck them back in after. Also, I had to bend the L brackets a little (prior to install) so that the plate lay flush. Obviously there is some measuring involved too to know where to place the brackets. For me it was 3.5" each way from center.
Ford Bronco Front license plate mount options? IMG_8794.jpg 2
Ford Bronco Front license plate mount options? IMG_8796
Ford Bronco Front license plate mount options? IMG_8793.jpg 2
Hellion10
Jerry
Denair Ca.
'19 Audi A7 Prestige, '23 Tundra Capstone, ‘69 C10
HBTFD
Newnan GA
F350
That mounting location is blocking the sensor for emergency braking which is on all Broncos.
Chester, NJ
Lotus Elise
I was told that the ACC would be the only concern with mounting there if equipped. Regardless, I have had the emergency braking turned off since day of purchase.
Aman
Aman
Northern NJ
I believe emergency braking uses the ACC sensor in conjunction with the windshield camera if equipped with ACC. If not, emergency braking soley uses the windshield camera.
HBTFD
Newnan GA
F350
Why would the box in the bumper be on all trim levels? My BD with the basic package has the box.
doktorek
Long Island
You just covered your tranny cooler (or power steering cooler) - Im not sure what cooler that is but it will shorten your engine part's life.
I still like my Vortex mount
Coldsmoke
Knuckles
Northern Illinois
Ford F150 Lariat
For all the unfortunate souls like me that are required by law to mount the front license plate: Has anyone seen any interesting options or alternatives to the stock mount?
I got the front license bracket from Builtright Industries and am tickled pink with it. It’s built like a brick shithouse and offers a plethora of mounting options to suit any preference. Best of all, it installs in 5 min or less.
