Front jack point
ksdon
kansas
Can the front lower control arm be used as a jack point?
How about right under the shock mount?
Wanting to lift a front tire off the ground but not wanting to lift as much as the chassis rail "official" lift point requires.
Frankie945
Frank
Louisville KY
Q50
I use front lca without issues I place my jack on the center of a shock bolt. Also kinda depends on what type of jack you are using to do it safety because you don’t want the jack to tip over after you have a lot of pressure on it.
ksdon
ksdon
kansas
I use the factory jack and a Unijack 6000.
Ducati1098
Ford says not to Jack it by the control arms because of potential damage. I’m sure they say this mainly from a liability standpoint, but just throwing it out there.
ksdon
ksdon
kansas
I can see their point for routine tire changing.
And I'm asking because I can see that the control arm is not ideal.
Thanks
AMTRV
Oliver
United States of America
22 Badlands 4dr, 22 6.7L Tremor, 1940 Ford Cpe
I guess I missed this bit of information.
It’s so good to have experts like this dude here! He knows a lot about most everything.😉
There isn’t a really good place to lift the front like the OP wants to do…..it won’t hurt a thing to lift at the lca but as mentioned, use a jack with a good base…..I use a floor jack
Ducati1098
No problem man. Like I said just throwing the info out there, not saying people NEED to follow it. I’d probably lift it by the LCA in a pinch too 🤷‍♂️ Here it is just for reference.
Ford Bronco Front jack point D8FB03C6-655A-48E1-8D82-7780A649A037
AMTRV
Oliver
Thanks!
JT58Bronc
JT
Fl
I surveyed the front end geometry and looked for safe lifting points other than the frame. My hydraulic heavy duty floor jacks did not have enough travel to lift the front of my Sasquatch to change or rotate the tires. I had to get a pressure treated 2 X 4 and cut 2 pieces to 5.5" long for each side to fit on top of my floor jacks and the frame lifting point to be able to lift it. It's the highest point I have had to jack on any vehicle I have owned. My jacks have a lot of travel, too. I would not recommend any other way to lift the front.
Jdc
Jon
Massachusetts
Bronco Badlands
I have a unijack. Are you using the scissor jack to get a bit more height? I tested the unijack in my driveway and was only able to get the tire about 1" off the ground but I figured if I used the scissor jack to lift the Bronco a couple of inches first then I'd be able to adjust the unijack's arm to get a couple inches more of lift
ksdon
ksdon
kansas
I use both factory and unijack at home also 2x6, 2x8 and 6x6 blocks if more height needed.
If under the vehicle, we have jackstands as well.
bytheway
Brice
Louisville, KY
I had to add wood blocks to my scissor jack to get it lifted and bought new 6 ton jack stands because I had the same problem.
