Front and Rear Diff Service: Drain and Fill Plug?
SPITmadFIRE
CA
Was browsing the WSM for servicing front and rear diff fluid — it seems as though the fill and drain plugs are single use on the M210/M220 diffs. Does anyone have a lead on where to find those part numbers? My search skills aren’t cutting it.
Ford Bronco Front and Rear Diff Service: Drain and Fill Plug? 1673916729340
Boreal
Colby
MB
www.cspencephoto.com
2022 Badlands 2DR
I’d personally feel comfortable reusing a plug, whereas OEM prefers new fasteners everytime.
Isn’t there a parts list attached to the WSM procedure? From most documents I’ve come across, they tend to have an itemized list
SPITmadFIRE
SPITmadFIRE
CA
I’ve only seen itemized parts lists on TSBs, not in each chapter of the WSM. They list “Materials” at the beginning of certain procedures but usually it only references the fluid, or special tools needed.
rtazz17
Connecticut
2022 Ford bronco big bend
No need to discard the plug. Taken my front out 4 times already. Had a cv axle issue.
RagnarKon
Ford Bronco, Escape, Focus
6C2Z-4N282-AA
Double-check me... or ask your dealer's part counter if that is correct. I'm working on a cell phone right now and the dealer parts website is horrific on mobile.
SPITmadFIRE
SPITmadFIRE
CA
6C2Z-4N282-AA
You both rock, thanks! Will double check the part number shortly
SPITmadFIRE
SPITmadFIRE
CA
6C2Z-4N282-AA
Looks correct to me! Even referenced correctly on the parts diagram, it seems.
Ford Bronco Front and Rear Diff Service: Drain and Fill Plug? 1673920649758
SPITmadFIRE
SPITmadFIRE
CA
Looks like the drain plug is 6C2Z-4N282-AA but the fill plug is E8UZ-4N282-A as far as I can tell?
Ford Bronco Front and Rear Diff Service: Drain and Fill Plug? 1673920845741
Tricky Dick
Dick
PNW
www.TD-Distributing.com
Not a chance in hell I'd be buying a new plug unless I lost one. I thought the 7MT TSB bolt replacements was a bit overboard but this is just too much.
SPITmadFIRE
SPITmadFIRE
CA
Just like your idea about those single-use driveline bolts, I’m pretty sure these drain/fill bolts have some sort of thread sealant pre-applied. From taking a look at the product images and the fill bolt on my front diff, it seems like they have some sort of white thread sealant on the threads.
Tricky Dick
Dick
PNW
Likely. I've seen sealant on drain bolts before. I've also put them back in without it.
I'm thinking about getting the Metalcloak rear diff cover. I should ask them to send a bag of extra plugs and see what they say. 😁
SPITmadFIRE
SPITmadFIRE
CA
Hopefully they just send you a couple rubber toilet tank stoppers on a little chain
