Front and rear bumper vertical alignment
MaverickMan
Shane
It can actually be adjusted from behind the wheel, but you have to wait for winter till they pile up snow piles in the corners of parking lots. Then just pick your side and hit it. Thats how I used to straighten my old CJ frames and gear shifters after hard wheeling.
NotApplicable
BEVs
NotApplicable
BEVs
looks fine,until i run into a few trees(more likely light poles at the mall lol)
Damn, I thought you were part of The Club©
JaxGtc
Early Broncos lean to the left, maybe they are just staying true to the original. :)
Ryno
Ryan
Prunetucky
My left🥜 is a tad lower than the right. My owners manual showed no adjustment. I was told to embrace it.🤷‍♂️
JMB
All Fords
Here is my front bumper, for example. You can see that the right (driver's) side sits slightly lower than the left. Hoping it's an easy adjustment! My rear bumper has the same issue.
Like I said, I've noticed the same to varying degrees in MANY Instagram and forum owners' posts, particularly with the HD bumpers. Don't hold me responsible if you go inspect yours and find similar when maybe you hadn't noticed it before now ;)!
Not an issue.
kkurni
WA
Mini Countryman
Looks like it's just the 6 bolts in pink.
Rear....
Did anyone try to adjust rear bumper?
From the picture the this is for horizontal adjustment instead of bring it up or down?
Do you need 2 person for this?
flip
Phil
IN
www.ruxerparts.com
Fords
Not much adjustment built in unless you slot holes. Best way to do is with two but can be done if you loosen bolts just enough where it moves with some force but not enough where it flops around. If its way off you may have something bent.
Delight
Delight
Cincinnati
Sequoia
My rear bumper (Bigbend 4dr) bumper was hanging lower on the passenger side than the driver side.
I was able to loosen the bolt on the right side curved slot...raise the bumper with a tall enough floor jack, retighten bolt and it is now level. The bolt was easy to loosen so assume that was the problem.
kkurni
WA
Mini Countryman
I tried with just my knees hold the bumper and loosen up all 5 screws. But could not make any much different.
The gap is now slightly less than 1 inch on passenger side but on driver side is 1/2 inch.
What is your gap after you adjusted?
Delight
Delight
Cincinnati
Sequoia
Just measured andIt's at 1/2" both.
Tanman
Ron
Thornton, Colorado
2021 Black Diamond 2022 Mini Cooper S
Rear....
Do you have a breakdown of the rear steel bumper? I'm trying to remove the end caps.
flip
Phil
IN
www.ruxerparts.com
Fords
Removal
NOTE:
Removal steps in this procedure may contain installation details.
  1. Raise the vehicle on a hoist.
    Refer to: Jacking and Lifting (100-02 Jacking and Lifting, Description and Operation).
Vehicles With: Rear Fog Lamps/Rear Parking Aid
  1. Disconnect the rear bumper wiring harness connector.
Ford Bronco Front and rear bumper vertical alignment video
Ford Bronco Front and rear bumper vertical alignment Hel
All vehicles
  1. On both sides.
    Remove the bolt.
    Torque: 20 lb.ft (27 Nm)
  1. NOTE: This step requires the aid of another technician.
    Remove the bolts and the rear bumper.
    Torque: 59 lb.ft (80 Nm)
Installation
All vehicles
