Fridge Strap
swooshdave
Portland, Oregon
Mustang
Until I find a good slide I just want to strap the fridge down using the built in “lasso” d-rings. I’m trying to find the right kind of strap for this. Suggestions? Fridge will be on the passenger side facing front to back.
Ford Bronco Fridge Strap 49D127D3-0934-46B6-8803-911B6A3BD10E
UtahBrandon
Brandon
www.puravidaoffroad.com
a number of classics and my 4dr Badlands
These work great. I take my fridge out often to haul cargo so I have no plans for a slide.
Ford Bronco Fridge Strap 7A37ADB8-E363-47C4-A47F-DD54B0C30449
Ford Bronco Fridge Strap 7C0D0248-737C-415F-987E-74B62658B549
Jr87mustang
Josh
Northern Cali
UtahBrandon
Brandon
Take note that if you strap it in like this to be mindful of any ventilation holes on the side of the fridge.
I placed these on the side of the fridge which also keeps the subwoofer from rattling against the fridge.
Ford Bronco Fridge Strap FFBB31F8-5207-44D0-A473-DC02D57E8077
emulous74
Seth
East Tawakoni, TX
'19 ZR2 Bison D , '23 Bronco 2DR, MT, '24 Lucid Air Pure
Any decent strap that you buy should have a weight rating on it, just make sure it's well beyond what you actually need. I would also check with the manufacturer of your fridge and see if the handles are rated to take the force of being strapped down by them. If they aren't I'm sure they have a suggested way and/or accessories of the proper way to tie it down. Also you will need to tie it down to the fridge slide too, so the straps you get now won't be wasted.
swami37
Fort Lauderdale Florida
1950 Ford F-1 and 2020 F150 FX4
swooshdave
swooshdave
Portland, Oregon
Mustang
I ended up going with the NRS straps instead of the Rollercams.
Just from an ease of ordering standpoint.
The NRS also have clearly marked straps and look to be very high quality.
Ford Bronco Fridge Strap AEB27832-DF5E-4DCA-B366-A0BB508FE7B3
Roger123
Roger
VA Beach, VA
swooshdave
swooshdave
Portland, Oregon
Mustang
utahmike
Utah, USA
Bronco Raptor
I am curious about fitment -- from photo, I assume you have ARB Zero 47qt, not the 63 qt. Did you consider the 63qt and find it is too big, when strapped down in your 4-door bronco?
