Fox Coilover alternatives?
Dom
Dom
Phoenix AZ
2000 Ford Expedition, 2013 Ford Fusion
I have the Stage 8 with the electronics. It’s definitely on par with the SDI EClik system I have in my Raptor. I wish the Icon ran a gauge like the EClik, but it is what it is.
It definitely works, and you can feel it. You make adjustments off your phone. I’ve only been on road so far, but I’m going to Baja in April. The only real bitch I have is after I bought the system, and had it installed (don’t like putting in suspensions without a lift), I found out the system is only compatible with an iPhone, and I had a Samsung Droid. Key the word “had”, 😂😂😂.
I know it’s somewhat expensive, but I really think it’s worth it. Especially if you plan on doing any off roading.
You should've bought a cheap Iphone. Then you could've mounted it and dedicated it to the bronco and suspension. Kept the android, becasue Apple sucks. LOL
Baja Bronco
2Sun AZ
22 Ford Bronco, 20 Ford Raptor
IDK, to me they’re all the same. I just couldn’t believe it when I called Icon, and they said their system works with IOS only. I asked if it would eventually be compatible with Android, and they said no, probably not.
  • Like
Reactions: Dom
Dom
Dom
Phoenix AZ
@BajaBronco Yeah, that seems a bit short sighted on their part.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
I'm waiting for the time to do KINGs......in the meantime I've had the Eibach Pro Lift Kit (springs only) and they perform AMAZING. Completely complementing my SAS Bilsteins. Great on-road and great off road.
Broncobro04
Broncobro04
Alex
Phoenix, AZ
2021 2 door Badlands
King and fox are like the two top of the line but I prefer the progressive valving of the fox shocks more. I ended up going icon spacer lift which honestly performs totally fine with the factory bilsteins
kodiakisland
Arkansas
A lot of companies go that route. The software I use for flying is only compatible with apple, so I have an iPad mini. I refuse to buy an iphone.
Baja Bronco
2Sun AZ
A loft of companies go that route. The software I use for flying is only compatible with apple, so I have an iPad mini. I refuse to buy an iphone.
Well, I kind of lucked out. During the month of December, if you bought an iPhone, they gave you an iPad. So there’s that. The suspension app works, so that’s the thing that counts.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
The Eibach lift is really amazing. Because its NOT a spacer lift, which will retain the stock spring/shock characteristics, the RATE that Eibach has figured out is a TOTAL compliment to the SAS Bilsteins. I did not change UCAs and went with RockJocks Rear Trailing Links and an ICON track bar. When I do upgrade to the KINGs, I will add on a Camburg billet Upper Control Arm.
Broncobro04
Broncobro04
Alex
Phoenix, AZ
Good stuff. Eibach is a good company, I thought about going with their coilovers but decided to cheap out. They make the springs for the fox coilovers.
