FORScan DTC error help when swapping headlights
pizzy
larry
Pa
2023 bronco base
Newbie help needed! After swapping out my standard headlights for the signature headlights, I am getting 2 DTC error codes in Forscan. The first is B14E5:55-0A and B14E7:55-0A. These are for the left and right headlights and are basically stating that I have not configured these modules. Can someone who has the signature lighting tell me what their stock configuration is so that I can change mine and get rid of the error codes? Otherwise, the lights themselves do seem to be working properly with the exception of the ring leds not turning on when opening the door when the car is off ....it is just that the error codes keep popping up in Forscan. Community assistance would be greatly appreciated! I posted this question in a cou[ple of differnt areas wasnt sure where the appropriate section to post was...
Ford Bronco FORScan DTC error help when swapping headlights frscan
Boosted2.3L
Robert
Detroit, MI
Badlands Bronco
Hey did you ever get resolution on this one? I didn't swap my lamps but I have the codes after adding fog lamps, not sure what I accidentally messed up via forscan.
pizzy
pizzy
larry
Pa
2023 bronco base
No I didn’t. Actually not one response to my issue. I still show the error codes whenever I hook up forscan
Does anyone who is familiar with error codes have any idea what settings to change to clear the dtc issue?
Ducati1098
Headlights have to be configured by the Ford diagnostic tool when replaced. That's the only way to get rid of these codes.
pizzy
pizzy
larry
Pa
2023 bronco base
Ok thank you. So that’s a service that can only be performed by the service dept at the dealer? Is there any one out there that switched from the base headlights to the signature headlights taken the car in to have the codes cleared? And I assume everyone who has done this swap encountered the same error code?
Ducati1098
Yes. I don't think forscan can do it, only FDRS.
Robr
montreal, canada
mustang gt 2020, ford bronco 2021 badland, Westfalia 1977
I have the opposite, everything was working fine until I went to the dealer where they tried to clear the codes and actually had my front flashers and amber lights not working.
