Forscan changes to activate 25+ trailer module?
pvirga88
Phil
2025 Ford Bronco Base 4dr
What is a no-go mean, you don't have access to the IPC?
What version of forscan specifically are you using?
Sorry for the late reply. I used the Beta version you recommended from Forscan. Still the same message as before. I ended up calling two dealerships to see if I can bring it in for a program. Still haven’t heard back from either of them yet. I hate dealers. Was hoping I can do it myself. But I don’t want to dig further. Afraid I’ll brick a module.
Jab7410
Jacob
San Antonio, Texas
Big bend 4door
See below for 2025 setting.
The TRM is much larger (more lines/ different, it a diffrent firmware module for 2025+)
also The ipc is slightly different
720-03-02 requires (2) changes
These are what I gave EastALHijet, and they confirmed it worked (for them)
as always:
back your own setting beforehand, and use at your own risk
Let me know if you have any issues
Instrument Panel Control Module720-03-02xx4xxx--Trailer Sway0=Disabled4=Enabled
Instrument Panel Control Module720-03-02xxxxx1--additional value for (1) is part of 2025 version for trailer Lighting
Instrument Panel Control Module720-07-01xxxxxCxxxx--Trailer Brake Controller4=TBC DisabledC=TBC Enabled
Body Control Module726-01-02xxx1xxxxxx--Trailer Connect Config0=Disabled1=Enabled
Body Control Module726-40-01xxxxx1xxxx--Trailer Outage Config0=Disabled1=Enabled
Body Control Module726-69-02xxxxxxxxx1--TRM Installed / Config0=Disabled1=Enabled
Parking Aid Module736-01-01xx8xxxxxxx--Pam Config0=No Trailer Module8=Trailer Module
TRM Trailer Module (TRM)791-01-019000000091BB
TRM Trailer Module (TRM)791-01-02070A000000AC
TRM Trailer Module (TRM)791-01-03000006A2
TRM Trailer Module (TRM)791-02-01A301004B4BD5
TRM Trailer Module (TRM)791-02-024B4B4B00007D
TRM Trailer Module (TRM)791-02-0300FA001900B0
TRM Trailer Module (TRM)791-02-040500320005DA
TRM Trailer Module (TRM)791-02-0500000A0003AC
TRM Trailer Module (TRM)791-02-06001E000E07D3
TRM Trailer Module (TRM)791-02-07D00000000071
TRM Trailer Module (TRM)791-02-080000000000A2
TRM Trailer Module (TRM)791-02-09000000A3
TRM Trailer Module (TRM)791-03-01D00064640034
TRM Trailer Module (TRM)791-03-0200009D
TRM Trailer Module (TRM)791-04-01000000FA0097
TRM Trailer Module (TRM)791-04-02FA00FA00FA8C
TRM Trailer Module (TRM)791-04-0300000000009F
TRM Trailer Module (TRM)791-04-04000000A0
TRM Trailer Module (TRM)791-05-0100000000009E
TRM Trailer Module (TRM)791-06-01FFFCFFFCFF94
TRM Trailer Module (TRM)791-06-02F33FFCFFFFCC
TRM Trailer Module (TRM)791-06-03FF007BFF3C56
TRM Trailer Module (TRM)791-06-048022
TRM Trailer Module (TRM)791-07-0103EA051404AA
TRM Trailer Module (TRM)791-07-024B0565010057
TRM Trailer Module (TRM)791-07-030100010001A5
TRM Trailer Module (TRM)791-07-040001000004A8
TRM Trailer Module (TRM)791-07-050005000400AD
TRM Trailer Module (TRM)791-07-065C0075005CD2
TRM Trailer Module (TRM)791-07-0705DC04C30654
TRM Trailer Module (TRM)791-07-088A0000000031
TRM Trailer Module (TRM)791-07-090000A8
Side Object Detection Left7C4-01-01Bxxx--Left BLIS3=Auto / No Trailer
B = Auto /Trailer
7=Manual / No Trailer
F=Manual / Trailer
Side Object Detection Right7C6-01-01Bxxx--Right BLIS3=Auto / No Trailer
B = Auto /Trailer
F=Manual / Trailer
Accessory Protocol Interface Module7D0-01-03xxxxxxx4 xx--Trailer Setup Configuration0=Disabled4=Enabled
Accessory Protocol Interface Module7D0-01-04xxx6xxxxxx--4 Pin/7 Pin Connector2=No Connector6=Connector
Accessory Protocol Interface Module7D0-09-02Cxxxxxxxxx--Trailer Sway4 =DisabledC=Enabled
Thank you so much! Worked on my 2025 big bend, even the testing on the ford app works perfectly!
ActionZ
Jackson
Vancouver
2024 Bronco 2.7
Yep, just this line needs to be changed.
Quick question, if I don't hardwire a brake controller and use the Bluetooth one when towing, do I still need to activate this? And I guess deactivate when I'm not towing and unplug the Bluetooth brake controller? Thnx
ActionZ
Jackson
Vancouver
2024 Bronco 2.7
everything in TRM, do I match that? Or is that what I should see when I program the other stuff with the xx4x. X—-
only ask because I am used to seeing it as Change this to this.
B = Auto /Trailer
F=Manual / Trailer
B = Auto /Trailer
F=Manual / Trailer
Stupid question but I keep the side object detection activated correct? Even when no trailer is attached?
RoverDude
Maryland
2021 Bronco (First Edition)
In your case, leave it disabled I believe
RoverDude
Maryland
If you have blind spot /object detection, and you have the the tow module, The system will deactivate blind spot monitoring when the trailer is attached.
It would be best to use the settings above for your configuration.
ActionZ
Jackson
Vancouver
2024 Bronco 2.7
Ok finally got to setting this up in forscan. I initially got TRM codes that can't be reset:
Most of my TRM values were different and I changed and wrote each individual one followed by an ignition on/off after each section. Then I did a quick search and another member in your original thread said the error was cleared after they did a Write All. I did it and all codes are now reset! Going to get a tester and try it out. Hopefully Swedemn can see this and reset his code.
2 odd things I found was in the APIM Trailer Setup Config, the hex placement seems to be different on mine. I changed 7D0-01-03 from xxxx xxx0 xx-- to xxxx xxx4 xx-- (as per the original chart) under "as built" setting but when I went into APIM easy mode, it still showed Trailer Setup Config to "disabled". So I changed the setting to enabled under easy mode and went back into the "as built" setting and it showed the xxxx xx4x xx--. The 4 was on the 7th value not the 8th. Is this an error on the original graph?
The other odd thing was under both the SODR and SODL, 'as built' setting, the values for automatic was put in. However under the corresponding easy mode menu, the transmission mode shows manual. Strangely, I checked the setting before changing anything and from factory it also showed as manual. Needless to say I have an automatic.
KSA_outdoor
Kevin
Tx
2025 2.7 Bronco
If I get a used/salvaged 2025 TRM, will I be able to install in my 25 Badlands or will it be vin locked to the original vehicle?
RoverDude
Maryland
You can install it, there is no Vin information in the trm
Formula260ss
Winchester
2017 F-150, 2025 Bronco
Ok, I have to ask. Is FORScan able to configure the trailer module on a 2025 Bronco at this point? I am thinking about buying and installing the hitch myself; however, I really do not want to pay the dealer $195 to program it.
Jab7410
Jacob
San Antonio, Texas
Big bend 4door
Yes, I just did it on a big bend
Formula260ss
Winchester
I want to thank everyone, especially @RoverDude for supplying the settings for the 2025 Bronco. I was able to install the hitch and do the programming this week and everything worked.
Kfuller1212
Kyle
New Jersey
2026 OBX SAS
Hello, just trying to confirm the correct part numberl for the controller for MY26 OBX hi lux package. There was a lot of back and forth about what is the new controller part number for MY 25-26. Any help would be great thanks.
kctango
Keith
Walthourville, GA
2025 Bronco Base Sasquatch
Hats off to Roverdude you are the man.
I've read and reread this entire thread. Then attempted to adjust all the settings in forscan. Backed up to my trailer, hooked up. AND Everything worked.
Thank you oh so much!
