Forscan changes to activate 25+ trailer module?
Pedey321
2025 Big Bend w/ Black Diamond Pkg
Hello all and thanks for all of the valuable info / help being a new Bronco owner. I've installed the hitch / receiver (went with a Draw-Tite 76527 for added spare clearance) along with a 4/7 pin outlet to bumper. Lastly installed / connected the MY25 module (PN M2DZ-19H332-A).
Perhaps I'm not correctly using FORScan or need to flash the basic (As-Built) on to the TRM (Ford PN M2DZ-19H332-A).
Now I'm attempting FORScan programming tasks with RoverDude's above specifics. Problem is I don't seem to have the base TRM lines shown above to modify
(only have what is shown below).
Screen shots below.
Any ideas / suggestions - thanks in advance...
Ford Bronco Forscan changes to activate 25+ trailer module? 1762981591058-05
Ford Bronco Forscan changes to activate 25+ trailer module? 1762981756167-yn
donalddon
New Mexico
2023 Bronco, 2022 Lightning, 2019 Crosstrek
Screen shots below.
i'm stuck here now. i can't figure how to get the rest to show. i was happy to see the trm show but it is only a little of it.
how did you get the rest?
RoverDude
Maryland
2021 Bronco (First Edition)
You need the correct module. MY 2025+ is a different module.
donalddon
New Mexico
i had installed all of the towing and hitch stuff a year or so ago, ford kindly made it all work for free! that service manager is no longer there- i wonder why...
all worked perfect and then i replaced the instrument cluster with a 2025- very pleased with that. i stood back and admired.
every thing is happy with itself except for a trailer brake modular fault.
i used an 'as built' vin which came with a factory tow package. i had to delete all profiles in forscan to get the new cluster to have everything i needed except trailer brake fault module.
i am at a loss
RoverDude
Maryland
Okay now I'm lost. What year of a vehicle do you have? Do you have a 2025 vehicle?
donalddon
New Mexico
no
it's a 23 wildtrak with a newly installed '25 instrument cluster
a few road blocks as i'm new to forscan and have been using macs for the last 25+ years. i'm still struggling with windows
RoverDude
Maryland
i added a tow package-i did the physical install and ford programmed it for me
What is the fault, what module is it associated with?
Was it the fault there after they programmed it I.e the dealership?
Did the fault occur when you replaced the instrument panel?
If so, did you make the associated changes in the IPC for the replaced screen/dash?
donalddon
New Mexico
no fault until i changed the cluster. the only icp change so far is i updated the miles.
the fault is: trailer brake modular fault
Pedey321
I have a 2025 big bend with black diamond package, 4 cylinders, 10 spd auto, 221A optioned, and current module (ordered PN: M2DZ-19H332-A, aka engineering PN M2DT-19H378-AB (as displayed on physical part) and not having more than basic 7 (791-0#-01) available.
This looks like a hardware and software (firmware) issue. Having worked in IT related industry, what is Ford's approved platforms and configurations (hw & sw)?
Perhaps this is just a firmware issue? What order pns and physical pns are compatible with what MYs and Vehicle configurations including PCMs?
Pedey321
J7st ordered a new / replacement module, for MY25 TM specifically (ordered pn M2DZ-19H332-A) and will try FORScan again.
Note: M2DZ-19H332-A (what I'd ordered) and M2DT-19H378-AB (marking on previous attempted to use part) are the same part supposedly even though the 30 or so lines are available vs. 7).
These are basically PLCs which perform specific functions (given hardware & software versions) and are supposedly managed (tested, validated for integrated revision / version acceptable performance) by the manufacturer.
Will update after attempting to install and configure replacement module.
kcmusa
kc
Georgia
2025 bronco bablands
i ordered M2DZ-19-H332-A in box was M2D2-19H378-AB. Did not work as tryed to program. So took it to dealer, they said I really need S2DT-19H378-BA. As they could not program it. Waiting for that part to try.
kcmusa
kc
Georgia
One question on the 25 for scan changes.
the TRM, do we make sure they match what’s here? As the config does not show , change x to something.?
RoverDude
Maryland
can you be more specific or a screen shot of what you're talking about
kcmusa
kc
Georgia
everything in TRM, do I match that? Or is that what I should see when I program the other stuff with the xx4x. X—-
only ask because I am used to seeing it as Change this to this.
Instrument Panel Control Module720-03-02xx4xxx--Trailer Sway0=Disabled4=Enabled
Instrument Panel Control Module720-03-02xxxxx1--additional value for (1) is part of 2025 version for trailer Lighting
Instrument Panel Control Module720-07-01xxxxxCxxxx--Trailer Brake Controller4=TBC DisabledC=TBC Enabled
Body Control Module726-01-02xxx1xxxxxx--Trailer Connect Config0=Disabled1=Enabled
Body Control Module726-40-01xxxxx1xxxx--Trailer Outage Config0=Disabled1=Enabled
Body Control Module726-69-02xxxxxxxxx1--TRM Installed / Config0=Disabled1=Enabled
Parking Aid Module736-01-01xx8xxxxxxx--Pam Config0=No Trailer Module8=Trailer Module
TRM Trailer Module (TRM)791-01-019000000091BB
TRM Trailer Module (TRM)791-01-02070A000000AC
TRM Trailer Module (TRM)791-01-03000006A2
TRM Trailer Module (TRM)791-02-01A301004B4BD5
TRM Trailer Module (TRM)791-02-024B4B4B00007D
TRM Trailer Module (TRM)791-02-0300FA001900B0
TRM Trailer Module (TRM)791-02-040500320005DA
TRM Trailer Module (TRM)791-02-0500000A0003AC
TRM Trailer Module (TRM)791-02-06001E000E07D3
TRM Trailer Module (TRM)791-02-07D00000000071
TRM Trailer Module (TRM)791-02-080000000000A2
TRM Trailer Module (TRM)791-02-09000000A3
TRM Trailer Module (TRM)791-03-01D00064640034
TRM Trailer Module (TRM)791-03-0200009D
TRM Trailer Module (TRM)791-04-01000000FA0097
TRM Trailer Module (TRM)791-04-02FA00FA00FA8C
TRM Trailer Module (TRM)791-04-0300000000009F
TRM Trailer Module (TRM)791-04-04000000A0
TRM Trailer Module (TRM)791-05-0100000000009E
TRM Trailer Module (TRM)791-06-01FFFCFFFCFF94
TRM Trailer Module (TRM)791-06-02F33FFCFFFFCC
TRM Trailer Module (TRM)791-06-03FF007BFF3C56
TRM Trailer Module (TRM)791-06-048022
TRM Trailer Module (TRM)791-07-0103EA051404AA
TRM Trailer Module (TRM)791-07-024B0565010057
TRM Trailer Module (TRM)791-07-030100010001A5
TRM Trailer Module (TRM)791-07-040001000004A8
TRM Trailer Module (TRM)791-07-050005000400AD
TRM Trailer Module (TRM)791-07-065C0075005CD2
TRM Trailer Module (TRM)791-07-0705DC04C30654
TRM Trailer Module (TRM)791-07-088A0000000031
TRM Trailer Module (TRM)791-07-090000A8
Side Object Detection Left7C4-01-01Bxxx--Left BLIS3=Auto / No Trailer
B = Auto /Trailer
7=Manual / No Trailer
F=Manual / Trailer
Side Object Detection Right7C6-01-01Bxxx--Right BLIS3=Auto / No Trailer
B = Auto /Trailer
F=Manual / Trailer
Accessory Protocol Interface Module7D0-01-03xxxxxxx4 xx--Trailer Setup Configuration0=Disabled4=Enabled
Accessory Protocol Interface Module7D0-01-04xxx6xxxxxx--4 Pin/7 Pin Connector2=No Connector6=Connector
Accessory Protocol Interface Module7D0-09-02Cxxxxxxxxx--Trailer Sway4 =DisabledC=Enabled
RoverDude
Maryland
B = Auto /Trailer
F=Manual / Trailer
B = Auto /Trailer
F=Manual / Trailer
The TRM are listed because those should be the exact same for everyone's vehicle (2025+ has different settings , but still the same across the 2025+ vehicles)
I listed all the values because they're only related to the TRM module.
The ones that have x's. Those are across different modules.
Instrument control panel , blind spot monitoring, the sync screen.
People can have different values based on configure etc.
Those X's can be different between everyone's vehicles and have nothing to do with the tow module.
I hope that makes sense.
Just send me a PM if there's something specific or I can help more.
