Forscan changes to activate 25+ trailer module?
EOD98
Las Vegas
2025 Bronco Badlands Sasquatch
Yep, just this line needs to be changed.
nstrument Panel Control Module720-07-01xxxxxCxxxx--Trailer Brake Controller4=TBC DisabledC=TBC Enabled
Perfect. Thanks brother!
Larry Tague
Larry
Reno, NV
2024 Wildtrak
If they're different than what you have, yes you should change them.
Question: I have a 24 WT and when I attach my bike rack which has lighting I loose my blind spot function as it thinks a trailer is installed. Is there a way in forscan to stop this?
RoverDude
Maryland
2021 Bronco (First Edition)
You could change the blis settings so it shows you don't have a trailer.
pkwest
Paul
Huntington beach ca
2025 Bronco
See below for 2025 setting.
The TRM is much larger (more lines/ different, it a diffrent firmware module for 2025+)
also The ipc is slightly different
720-03-02 requires (2) changes
These are what I gave EastALHijet, and they confirmed it worked (for them)
as always:
back your own setting beforehand, and use at your own risk
Let me know if you have any issues
Instrument Panel Control Module720-03-02xx4xxx--Trailer Sway0=Disabled4=Enabled
Instrument Panel Control Module720-03-02xxxxx1--additional value for (1) is part of 2025 version for trailer Lighting
Instrument Panel Control Module720-07-01xxxxxCxxxx--Trailer Brake Controller4=TBC DisabledC=TBC Enabled
Body Control Module726-01-02xxx1xxxxxx--Trailer Connect Config0=Disabled1=Enabled
Body Control Module726-40-01xxxxx1xxxx--Trailer Outage Config0=Disabled1=Enabled
Body Control Module726-69-02xxxxxxxxx1--TRM Installed / Config0=Disabled1=Enabled
Parking Aid Module736-01-01xx8xxxxxxx--Pam Config0=No Trailer Module8=Trailer Module
TRM Trailer Module (TRM)791-01-019000000091BB
TRM Trailer Module (TRM)791-01-02070A000000AC
TRM Trailer Module (TRM)791-01-03000006A2
TRM Trailer Module (TRM)791-02-01A301004B4BD5
TRM Trailer Module (TRM)791-02-024B4B4B00007D
TRM Trailer Module (TRM)791-02-0300FA001900B0
TRM Trailer Module (TRM)791-02-040500320005DA
TRM Trailer Module (TRM)791-02-0500000A0003AC
TRM Trailer Module (TRM)791-02-06001E000E07D3
TRM Trailer Module (TRM)791-02-07D00000000071
TRM Trailer Module (TRM)791-02-080000000000A2
TRM Trailer Module (TRM)791-02-09000000A3
TRM Trailer Module (TRM)791-03-01D00064640034
TRM Trailer Module (TRM)791-03-0200009D
TRM Trailer Module (TRM)791-04-01000000FA0097
TRM Trailer Module (TRM)791-04-02FA00FA00FA8C
TRM Trailer Module (TRM)791-04-0300000000009F
TRM Trailer Module (TRM)791-04-04000000A0
TRM Trailer Module (TRM)791-05-0100000000009E
TRM Trailer Module (TRM)791-06-01FFFCFFFCFF94
TRM Trailer Module (TRM)791-06-02F33FFCFFFFCC
TRM Trailer Module (TRM)791-06-03FF007BFF3C56
TRM Trailer Module (TRM)791-06-048022
TRM Trailer Module (TRM)791-07-0103EA051404AA
TRM Trailer Module (TRM)791-07-024B0565010057
TRM Trailer Module (TRM)791-07-030100010001A5
TRM Trailer Module (TRM)791-07-040001000004A8
TRM Trailer Module (TRM)791-07-050005000400AD
TRM Trailer Module (TRM)791-07-065C0075005CD2
TRM Trailer Module (TRM)791-07-0705DC04C30654
TRM Trailer Module (TRM)791-07-088A0000000031
TRM Trailer Module (TRM)791-07-090000A8
Side Object Detection Left7C4-01-01Bxxx--Left BLIS3=Auto / No Trailer
B = Auto /Trailer
7=Manual / No Trailer
F=Manual / Trailer
Side Object Detection Right7C6-01-01Bxxx--Right BLIS3=Auto / No Trailer
B = Auto /Trailer
F=Manual / Trailer
Accessory Protocol Interface Module7D0-01-03xxxxxxx4 xx--Trailer Setup Configuration0=Disabled4=Enabled
Accessory Protocol Interface Module7D0-01-04xxx6xxxxxx--4 Pin/7 Pin Connector2=No Connector6=Connector
Accessory Protocol Interface Module7D0-09-02Cxxxxxxxxx--Trailer Sway4 =DisabledC=Enabled
I just wrote all these modules on my 2025 mid heritage. Everything but the Instrument Panel Control Module worked. I got an error when I tried to write that module. Any ideas? its the latest version of forscan v2.3.70.
"Gain security access failed - security key is wrong"
Ford Bronco Forscan changes to activate 25+ trailer module? IMG_0015
pkwest
Paul
Huntington beach ca
2025 Bronco
Removed to not add my confusion to this thread. Don’t change tire diameter without the relearn procedures
RoverDude
Maryland
The IPC, did you write all or just the lines that changed?
There's security on that because you know the instrument control panel also has the odometer data.
I do believe you should be able to write the individual lines I mentioned.
Do not write the entire module
pkwest
Paul
Huntington beach ca
2025 Bronco
Probably did a write all. Makes sense, I’ll try individual changes. Thanks
7MT
Erica
Cajitttt/89
2025 Big Bend
Hi, I installed my trailer mod today and followed the forscan chart. I am now getting cross traffic fault while driving. Anyone know how to fix that?
Thanks
pvirga88
Phil
2025 Ford Bronco Base 4dr
I am running into the exact same issue. Did you ever resolve it?
7MT
Erica
Cajitttt/89
2025 Big Bend
Figured it out. because it's a manual I had to put in different changes for the for the blind spot monitoring. No issue now.
pvirga88
Phil
When writing this
I get a Gain Security Access Failed message.
All other writes worked on the BCM, just the IPC won't write. I am pretty sure I am just writing this single line as well. as I wrote the BCM in the same manner, line by line.
Anyone else solve this issue? I have a 2025 Bronco Base 4Dr. Pretty sure If I am able to write this single line, my trailer lights will finally work. Saving me a trip and some $$$ at the dealership.
RoverDude
Maryland
There is updated version of forscan that's in beta that has updated security key access for 25+ IPC.
This is a known issue
If you have a license you should be able to get it at the beta section.
If not, wait until that version gets published in a new updated version.
pvirga88
Phil
cool thanks! I have a licensed version. I’ll check it out! Thanks man
pvirga88
Phil
Still a no go! I bet it’s due to the new module for the 25/26 year. I had to buy the ford kit specifically for my year.
RoverDude
Maryland
What is a no-go mean, you don't have access to the IPC?
What version of forscan specifically are you using?
