Forscan 2.3.66 Speedo Recal
Playing around with fixing my cruise control and attempted to reset/cal the speedometer. But the PCM/AWD re-Init procedures are gone so I could not clear the AWD DTC.
Have these been relabeled or did I do something wrong here?
I can still adjust it with ProCal module but it’s a pain swapping between ProCal and Forscan
B22-2023
Houston
I don’t know if FS 2.3.66 relabeled or dropped it or not, and this is another kind of pain, but you could go back and load a prior release of FS and access it there like the old days.
Ducati1098
I’m on beta 2.4.18 and just changed the speedometer for a coworker yesterday. You may want to upgrade to one of the newer beta versions if it’s missing for some reason on your version.
Yup it was in the beta - good call. Now that I’m done playing and don’t need the speedo stuff - just BMM.
Which also still fails on the beta, still waiting on FDRS to come up
Got it with Forscan Beta
When it tells you to push the brake — do NOT push the brake. Just click ok.
So for all you 2.3L out there that can’t get the Contra Code to work - Forscan can do it
For folks confused why this is in this thread — I updated the wrong thread. Meant to put it over here:
https://www.bronco6g.com/forum/threads/stuck-in-brake-maintenance-mode.116686/
Carry on.
Ducati once again carries the day with his suggestion to try the Beta, it seems to have corrected most ills
