Changed my tire diameter, relearned PCM, relearned AWD, reset DTCs, but advancetrac warning still pops up.
Any ideas?
Any ideas?
PCM, ABS, AWDWhat dtc codes are present.
No just the tire circumferenceThe numbers and descriptions should lead you to help for them I assume you have forscan. I had to clear twice in my wife’s ‘22 and take it for a short drive. Did you change the tpms psi too?
that’s why. That number is way too high. It’ll never accept that.2934
I may be wrong but I thought it was capped at 2800 what size tire did you go with? I have 37’s on order.2934
I have 37s. What’s the highest it’ll accept?that’s why. That number is way too high. It’ll never accept that.
37s. NittosI may be wrong but I thought it was capped at 2800 what size tire did you go with? I have 37’s on order.
From my experience, 2880 is the highest you can go. My 37” nittos were perfect at 280037s. Nittos
No problem. That’s still going to be way too high though, but it shouldn’t set a code. Like I said, my 37 Nitto trail grapplers match gps speed perfectly at 2800. Good luckSweet I will try 2880! Thank you
