- Bill
- May 17, 2022
- 11
- 22
- 34
- Central Texas
- Ford
- Outer Banks
Like many of us, I didn't know which compressor to get. I am a VERY average user. Maybe even below average, i.e. off-road maybe 2 or 3 times a year.
I didn't want to spend a lot of money getting an onboard compressor. check! I wasn't even too thrilled about spending $1000 for a dual-compressor ARB. I mean I understand those compressors are faster, bigger, bolder, and better! The supermen of compressors. But, still, $1000 [okay, not quite but close]. I just couldn't justify it.
So, I opted to use my FORDPASS points to get the ARB compressor. I know, a dinky single compressor. I've read all the comments: "Spend the extra money, it's worth it." "Much faster." "You'll be upgrading sooner or later, so . . . .[spend the extra money.]
I was particularly interested in the TIME element of airing up. I couldn't get any accurate estimates for the amount of time it takes to air up tires. The comments were all over the map. So, received my compressor, ordered a RHINO air guage [ARB couldn't deliver one for some reason] and, yes, the RHINO air guage is ALSO good enough for 90% of you! ["good enough" is not a bad thing. I couldn't identify any deficiency. The pressure reading matched the onboard pressure indicators as well as those at the local Firestone store.] Air guage is digital, seems well constructed, is priced at about 60% of the ARB product, and comes with a handy carrying case! Good enough for me!
i REALLY wanted to know how long it takes to air up a tire. Nothing dramatic, e.g. from 15 lbs to 35 lbs, just something kind of average.
I inflated each of my tires from about 33 PSI to 39 PSI in about 45 seconds. Call it a minute. I get it, that's not very much. Assuming a minute for every six pounds of air needed. Say FIVE minutes to air up from about 25 PSI, the pressure at which Bronco Roadeo tires are set. TWENTY minutes, maybe less filling tires. Three times per year. An hour per year wasted filling tires per year. Maybe only 30-minutes because a dual compressor will also take time.
$450 price difference over five years? 2.5 hours additional time filing tires more than a dual compressor. $450/2.5 extra hours = $180/hour. So, how valuable is your time? I'd rather spend that money on some other ridiculous accessory or at the nearest bar.
NOW, if you are hard-core, go out 3 times a month instead of 3 times a year. Go at the rocks rough and ready, then maybe a single compressor is not for you.
If, however, you just need to air down your tires a bit for rocky roads, trails, bumps, and what-not , then maybe a single compressor will work for you. [There are other brands that may be as good as the ARB. The ARB/Ford Performance kit seems well constructed and organized.] Best use of my FORDPASS points I could think of. I'm in this compressor, that comes with a handy carrying case, for less than $100.
Good enough for me. Good luck to all!
