Ford posts official Bronco mule off-road testing video
Tslater1989
Tyler
Central Michigan
2001 f150, 2016 explorer, 97 f150
Nope, 7.3 is longer and taller... in fact, it's significantly longer, to the point that the engine alone wouldn't fit in a Mustang without cutting into the firewall
"Godzilla" is a truck engine, Coyote is a sports car engine. Godzilla is pushrod and made to make power just above idle, whereas Coyote is made to rev out high and make power at the very top of the rev range. Coyote is overall smaller and lighter, revs higher but doesn't make as much torque (essentially meaning same speed but less likely to spin tires), whereas Godzilla is bigger and heavier, makes gobs of torque but hits fuel cut about 2000rpm lower, and would probably roast tires from idle but lose steam after that
Not saying you are wrong. Just saying, I had read that it would fit in the mustang with modification to the cowl, not the firewall. Doesn't matter anyways, its a pipe dream to wish that in a factory bronco. I was disappointed when I heard the 4.8l pushrod v8 that was in the works got shelved. THAT would be perfect for the bronco. I would guess the new 7.3 will be somewhere in between the 351 and 460 for outside dimensions which is more narrow than the 5.0, but longer with the water pump.
frinesi2
MD
'92 Pajero 2.5TD, '99 Land Cruiser '15 Golf TDI
I wish they'd bring back throttle cables
Remind me, why'd they switch to Fbw?
Emissions regulations. All road-car engine development is driven first and foremost by the need to meet emissions regulations.
Jalisurr
Oklahoma
'09 Corvette Z06, '97 Mitsubishi Pajero Evo
Plus, throttle by wire allows for:
cruise control entirely in software without extra components
different throttle mappings for different drive modes
Launch control (not really relevant to Bronco, but still)
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
Gotcha, gotcha
BAUS67
redneck
Central PA
Those Damn EPA agents !!!!!!!!!!!!!!!!! plus I think the Godzilla is for F-450 and bigger, motorhomes and such that do not fall under the EPA regs for fuel mileage and emissions that the 5.0 does.
BAUS67
redneck
Central PA
my bored/stroked 460 is at around 600 horses. running pump gas with 11.5:1 comp and a slightly reworked block and very reworked heads. she also turns 7k RPM. 513ci
A Boss 9 is close to the 4 digits on hp and torque. Uses a 429/460 block just a set of heads, intake, and a cam to match.
Nanook
Jonathan
Raptor, Bronco, Galaxie, Ducati Streetfighter V4S
Gotcha
In that case, bring out Gojira and a manual that can handle that beast. Also would get tasteful rice with a Godzilla badge on the side
Wait a second, LS motors are Pushrods, so essentially bored/stroked LS7 vs Coyote in a nutshell
Big Block Pushrod vs Coyote
LS7 is a small block
BAUS67
redneck
Central PA
although it is a "clean sheet of paper" build I would not classify Godzilla as a big block, more a BIG inch small block Would have to do some checking but don't think the 7.3 is a big as a 429/460 block only slightly bigger the Coyote. IMO
Jake_zx2
Jake
2018 Mustang GT
Nope, it's a big block. I can't find the article where Ford themselves call it a big block, but this one does quite a few times https://www.autoguide.com/auto-news/2019/02/ford-building-new-big-block-v8-for-heavy-trucks.html
I really think you guys are severely underestimating just how big this engine is
The Pope
It's in F250 and up....
It was designed to fill a gap within the engines offered. It's currently a Naturally Aspirated offering, but it's built with components that can handle Forced Induction.
There's a YouTube Video where Ford goes through all of this.
Found the video:
BAUS67
redneck
Central PA
First off you must have missed the first part that said clean sheet of paper, so they can call it anything they want. Yes I heard them "call" it a big block but to me it is more of a small block sized. I believe it is smaller than 429/460 block. For us old guys it goes small block 260, 289, 302, 351. big block 429/460 that replaced 352,390,428,and the badass 427 side-oiler. I'm sure some will correct me if I'm wrong but, for the most part that was the lineup for a looooooong time, then came the MOD motor in 96 it all changed no more pushrod. :angry: I don't want high winding I want torque that's what puts a smile on your face.
If I am correct Brian Wolfe headed up this engine development and back in the late 80's he also helped work on the gt-40 development for the 302(5-OH as everyone knows it know). It was a higher flowing head and intake package sold in the now Ford Performance catalogue. so he is a "small block" guy, and old school.
It is AWESOME he brought back the pushrod, I thought it was gone forever. Just to highlight 5-Oh 2 bolt block good for about 500 ponies with forced induction. more than that, ……. borrowed time. Then time to upgrade to a 4-bolt main good for 4 digits then. Goadzilla ...….. it has 4-bolts in the mains and has 2 cross bolts in the block that tie into those mains for a total of 6 bolt mains !!!! Guys this motor is ready for a set of twin turbos RIGHT OTTA THE BOX. If Brian Wolfe would be a women I would be in love. LOL If Ford offers this in the catalogue as a crate motor I can see it selling. I would have been in heaven back in the day for Ford to have offered something like this.
Don't take this the wrong way. Not trying to argue just putting it in perspective. To us old school guys most think of big block as 429/460 achitecture.
Jake_zx2
Jake
2018 Mustang GT
It's pretty close actually. Bore spacing in the Godzilla is only .3" smaller than the 429/460 (which is still bigger than any small block V8 on the market), and bore diameter is only 3mm smaller... in fact, it has larger bore diameter than many Chevy big blocks! I'm telling you guys, this Godzilla is a lot bigger than yall think it is
BAUS67
redneck
Central PA
Ok got "cha
I have not researched a lot about it and was in the dark about Godzilla for some reason I hadn't realized what the new 7.3 gas motor really was at first.
so in retro ….you are right it might be a tad on the large size for the Bronco but in any resto mod it would be great and like said it is a 6-bolt main for that durability to make it forced induction. BUILT FORD TOUGH.
Jake_zx2
Jake
2018 Mustang GT
Ok got "cha
I really think it would be badass to throw that engine into an old Galaxie or Torino or something like that. Not exactly fit for a Mustang or a Bronco, but would be awesome for a real muscle car!
