Ford posts official Bronco mule off-road testing video
Rogues Gambit
Eatontown, NJ
'19 Ram Rebel, '07 A4 Quattro
I once made some comments about ACT clutches online in a high HP Honda I owned ( I know oxymoron) but the President of the freaking company reached out to me for feedback. I have also beta tested products for Rally Armour for STI development. I guess being an enthusiast brings with it some perks.
Nothing wrong with Honda's, they're pimpy and got serious potential, especially with the right engine
Whatcha have now, Hatchback with a B18?
Tslater1989
Tyler
Central Michigan
2001 f150, 2016 explorer, 97 f150
If ford is here and lurking. Somebody will figure out a way to put a solid axle under it if you don't. If you are going to do it, make sure its more stout than the dana 44 too. That'll give you some serious off road cred. Honestly, instead of trying to import axles, the HD dana 44 kit for the wrangler is available from DANA. Whole axle in a crate. Its not difficult to imagine them making an axle kit for the bronco too. 4 inches of lift, remove cross members from under the engine. Weld new lower profile ones. Measure back to a certain point on the frame, weld/bolt link mounts. Utilizing the stock coil buckets for some soft springs, longer shocks that let the axle droop. Beefy anti-roll bar with disconnects. Got yourself quite a toy. Somebody will do it in no time.
Oh, and the new 7.3, its small enough to fit, I'm sure of it. Work on that too ford team lurker.
I have no issues with IFS, if done right... High angle, heavy duty ball joints, and stout steering gear. I'm sure it will take most people anywhere they want to go.
Oh, I'm in engineering too, so I am to be respected and acknowledged. :crackup:
Back to what this post was originally about. From what I can see, its doing more off-road in this one video, than what most of these broncos will do in a lifetime. That doesn't mean it shouldn't be a hardcore off roader though. Essentially, if its going to talk the talk. It needs to be able to walk the walk.
Tslater1989
Tyler
Central Michigan
Another idea for our ford lurker.... Offer a special warranty. ***30k mile 3 year, abuse included warranty coverage. We'll stand behind what we are building. Its tough, if you can break it that quick, we'll fix it.*** that would bump initial sales quite a bit.
BAUS67
redneck
Central PA
doesn't Ford already build this ?????? think its called the Troller :like:
dmtndan
1991 Silverado, 2014 Malibu
Love the idea of that, but these major companies make HUGE $$$ on spare part sales. So I would say slim to none on that sadly.
Tslater1989
Tyler
Central Michigan
Yep, thats why I mentioned having to import axles. Ford COULD do it. Make a SFA variant of the bronco, but just because they can, doesn't mean they will.
OX1
jackson nj
59 Brd, 70, 78, 79 Brncs, 84 LTD 331, 86 Cpri 5.0 Trbo, 17 Fsion Sprt, 21 GT 500
Bore spacing significantly more than coyote could be an issue.
Tslater1989
Tyler
Central Michigan
Can't remember where i read it. But the godzilla 7.3, is physically significantly smaller than the coyote 5.0 in width, slightly smaller in length, and i think it might be a touch taller. Either way, if ford did put it in the bronco. I will sell everything I have to buy one. Luckily I dont think they will. Which is good, I like my tools.
Rogues Gambit
Eatontown, NJ
Oh snap, really?
I'm terrible with figuring out the actual size, but if that's the case, then I'll take Gojira there in a heartbeat
Also, just for fun:
BAUS67
redneck
Central PA
Oh snap, really?
Also, just for fun:
Tires, skid plate, off road tires, and most important disconnecting the sway bar … Let it flex.
Driver's ability has ALOT to do with it and the right spotter (did you hear him on the radio) . Looks like it's 'gonna need a little body work when done also.
I only watched it once but ….. wheel base has a lot to do with it and to be quite honest I bet my Explorer with some "prep" work could manage a good show.
Rogues Gambit
Eatontown, NJ
Just saw it on the JL board and before I read the rebuttal, figured why not share it
True, bet my parents Range Rover's could manage that as well
OX1
jackson nj
@ 1/2 inch larger bore, seems unlikely it is smaller in length, but I can;t find actual dimension anywhere.
Obviously if a 7.3 was dropped in, I would be buying one day one. Even a 5.0/SFA combo might
make me pony up close to $50K.
Rogues Gambit
Eatontown, NJ
So if the two make similar power, what's the difference between the Coyote and Godzilla
Assuming the latter weigh less and revs lower
Randy92Fox
Randy
Washington
66 Half Cab, 7.3 Powerstroke, 5.0 Convertible Fox
Pushrod vs Overhead Cam. Pushrod engines make power a lot lower generally speaking. Less internal parts (camshafts).
I'm sure someone with much more mechanical knowledge will give a more detailed breakdown lol.
Think the old 5.0 EFI mustang of 1995 vs 4.6 of 1996. Both rated at same peak hp and torque but if you've driven both (I've owned both) the 5.0 just has so much more low end and you really have to push the 4.6.
