Ford Performance Tune
ARC77
AC
Los Angeles
2026 Ford Bronco Raptor , 94 Supra
Hello everyone. Just received the FP tune/procal … excited to install it however ! I believe I should/would wait to hit at least a bit over 1k miles lol
thoughts ?
stevenstommyboy1
Thomas
Menasha Wisconsin
2023 Bronco Raptor
Install any time you like. Just because you have the procal installed will not harm your engine. If you like break the motor in slowly and wait to romp on it. But when you do get on it you will smile.
ARC77
ARC77
AC
Los Angeles
Absolutely 😁😁👊
GA2Dr
Marietta, GA
2024 Bronco 2 DR 2.7
I don't think you need to wait any amount of time but I also think putting 1k miles on before you do it is not a bad idea - that way you won't be tempted to romp on it before 1k and also you'll have some baseline of what it was like before the ProCal.
Keep in mind the warranty ProCal has starts from 0 miles (such as it is), regardless of when you install it.
If you are trying to break in the engine, I would agree that waiting until that's done is probably a good idea -- because once you install ProCal you are gonna want to test it out.
RaptorBuilt
2025 Bronco Raptor, 2026 Hummer EV
I’d definitely wait until you cross that 1,000-mile mark. It is tempting to flash it right away, but sitting tight for a few hundred more miles is the smartest move for a couple of reasons:
• Let the engine fully break in: Ford’s official break-in period is the first 1,000 miles. You want your piston rings to seat perfectly and the mechanical internals to settle completely before throwing extra boost and aggressive timing at it.
• Establish a healthy baseline: Especially since you just dealt with that faint "valve noise" (which was almost certainly a little bit of spark knock/LSPI from a low-octane dealership fill-up), you want to burn through a couple of clean tanks of premium 91/93 first. Let the PCM establish its normal baselines on good fuel before you change the software.
• The "Infant Mortality" rule: If a sensor or part has a manufacturing defect, it usually rears its head in the first 1,000 miles. If something minor acts up on a bone-stock truck, it’s a zero-hassle warranty claim. If it happens right after flashing a tune, it just opens the door for dealership finger-pointing, even with the Ford Performance warranty.
Run it to 1,000 miles, get that first oil change out of the way to clear out any initial break-in material, and then flash it. You’ll appreciate the jump in torque even more!
ARC77
ARC77
AC
Los Angeles
THANX👍
ARC77
ARC77
AC
Los Angeles
Update - a few hours ago I uploaded the ford performance tune. Drove it around. Either I’m trippin or it’s slower than stock. The boost doesn’t kick in as hard as it was this morning ! Not sure if it needs to calibrate which I doubt … anyone can chime in … tnx
RaptorBuilt
You aren’t trippin' at all, but don't panic yet—the truck isn't broken.
This is a super common reaction right after flashing the Ford Performance calibration on the 3.0L.
Two main things are happening right now:
1. The KAM (Keep Alive Memory) was completely wiped.
When you flashed the tune, it reset all the engine and transmission adaptive learning to absolute zero. Right now, the PCM is running ultra-conservative baseline maps for safety. The knock sensors and Octane Adjust Ratio (OAR) have to re-learn the fuel quality in your tank before the computer opens up full timing advance and aggressive boost.
2. Ford Performance uses a linear throttle map.
The factory stock tune uses a highly aggressive, non-linear throttle "tip-in." When you push the pedal 20% stock, the computer secretly opens the throttle 50% to make the truck feel snappy around town. The FP tune smooths this out to be completely linear—which is way better for precise off-road control, but means you actually have to dig deeper into the pedal to get the same initial punch. It alters your "butt-dynamometer" perception until your foot adjusts.
Recommend:
Fuel: Make sure you are running Top-Tier 93 Octane if you can get it. The ProCal scales back power aggressively if it detects lower octane.
Drive it: Give it about 50 to 100 miles of mixed driving.
Wake it up: Find a safe highway stretch and do 3 or 4 rolling, heavy-throttle pulls from 40 mph up to highway speeds, then let it coast down naturally. This forces the PCM to rapidly map the load tables and advance the timing.
Give it a few days to settle in. The low-end "shock" will stay smoother than stock, but you'll notice the mid-to-high-end pull (4,000–5,500 RPM) carries significantly harder than it ever did before.
swamp2
This is speculative and to my sensations false.
Although it's very clear to any experienced foot/butt combo that both with and without the FP tune, that Normal mode has a much more linear throttle map than Sport mode (Sport being as you described above as with FP tune). It's also quite evident to me that any changes from the FP tune are much smaller than the Normal to Sport differences (either before or after FP tune).
This could be settled by logging some data, I think both % pedal depressed and % throttle open are both available all least in a tool like HPTuners sw.
ARC77
ARC77
AC
Los Angeles
Hi. So as raptorbuilt states above (Thank you ) I did take it for a few freeway runs and also performed the wot from 40mph to 65 ish and then let off and did some normal cruise here and there. So about 40 miles just for today. I did notice a smooth-er shift points and in sport mode the downshift when letting off throttle was more settled in. It does boost all the way to 28-30psi from take off at stand still that initial stock pull is a bit less. Untill you’re over 35 and when pedal depressed it pulls all the way to red line smoothly. It’s a quicker throttle response as well ! Now what you’re telling me is from the procal I’m able to adjust the throttle response ?
Ducati1098
Do you mean 18-20? Because there’s no way it’s making 28-30 on a FP tune lol
Also just remember that even with the FP tune, there is still a TON of torque management built in preventing very hard acceleration off the line. The only way to get rid of that is a custom tune
swamp2
No, not what I said nor meant. Without some crap like a Pedal Commander throttle curve is not adjustable. The primary Bronco modes do plenty of throttle curve adjustments.
ARC77
ARC77
AC
Los Angeles
Recommend:
Hi there. And thank you for this detailed note. I’m used to tailoring my Supra with AEM infinity 6 and previously with motec and have used the Banks derringer on my diesel jeep which is just a boost controller. That’s it. So the FP tune is new to me. It does feel better and faster on the throttle as I replied below to swamp2. I will keep you guys posted. And again thank you for the info and how to do some simple driving and wot to get it going. I was going to add a gallon of E85. But wasn’t sure. I’m always on 91 Oct fro. shell. For daily driving and occasional fooling around on the freeway as we all love to do. I’m happy so far. I will be installing hard pipes and air intake. Then maybe downpipes. Just for my own
ya I’m not wasting $ on that shit
ARC77
ARC77
AC
Los Angeles
All of my boost gauges I’ve owned /installed the First of the dial sweep /half is 15 psi and the end of the needle sweep is 30+ unless it’s In BaR which I highly doubt , I will check it with the Raptor button thing and see … the boost went to the end dial each time Is that 20 psi on the broncos ?
