Ford Performance Hood Struts installed
Doc TOC
Los Angeles
Expedition Max, Fusion Hybrid, BMW 5 Series, HD Road King
I like that mount-near-the -firewall style of hood struts.
I do not like the style that runs from the middle of the fender and blocks the side fender access. That style is not worth a wooden nickel.
Found a pair of Redline/IAG/Steeda/RC/Ford style hood struts on Amazon for half the price. Had these for a year now. Workgreat. Flip the release button, give it a light push, and up it goes. Grab the latch loop, a mild yank, and closed. Has never disappointed.
Murraydog11
Rick
2021 2Dr Outer Banks, Jeep Cherokee
I have the similar Redline Quicklift struts that I paid about the same for. This is one of the easiest and most beneficial modifications you can make to your Bronco. The only thing I'd rate higher is an updated oil drain plug, like the Valvomax or similar (if you change your own oil).
I went with the Steeda setup. I also went with the Ronin oil plug as I do change my own oil. Love them both.
Ford Bronco Ford Performance Hood Struts installed 20221010_170026
Ford Bronco Ford Performance Hood Struts installed Ronin
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
that was like the 1st mod I did, should've come out of the factory like that.
Nacho23
Massachusetts
2023 Bronco
One of the first things I bought for mine and absolutely love them! Show that ford pride, just be sure to wipe them down throughout the year, the rust will find them otherwise!
