Ford oil change intervals
jaruss01
NJ
5k miles is 14 months??
Same boat. It takes me well over a year to put 5k miles. And bronco will probably be even longer since my wife likely won’t touch it. I try to not wait more than 12 months for an oil change.
For me the biggest upkeep is making sure I run it often enough so the battery won’t die and the mechanicals stay lubricated since my car sits for 2 weeks straight fairly regularly.
Scott1911
Oklahoma
2 Door BadSquatch
Modern engines and the associate oil can easily go 20K miles. Therefore, the 10K oil change is more than adequate under normal driving conditions. Any of you certified in Tribology?
For those of you who insist on 3,000 mile changes, Do your change your points and plugs every 12K?
da_jokker
Jeep Wrangler JKUR
Man 20k would evenake.me nervous. With the turbos the oil is under extra stress...but who knows...I may do a few 5k ones and then send a sample to Blacklabs, specifically asking if their findings would support an additional 5k with turbos.
NotApplicable
BEVs
Do EB TTs use oil for cooling and lube or just lube? The 3.5 at least uses water cooling right
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
First one at about 2500, then every 4500-5K, full synthetic. It's really hot in South Florida. I do my own oil changes.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I know there were a lot of personal opinions in this thread - but, now that there have been a few deliveries- what’s the consensus on first oil change? Just after break-in or allow another 1k with factory oil?
We’re going out of town with it next weekend and it determines whether I get it done before or after the trip.
da_jokker
Jeep Wrangler JKUR
Unless the owners manual specifically says it needs to be changed super early, I'm not changing mine until the normal 5k
Now if you have at least a couple k already on it before your trip, and you plan on driving it hard or putting another 3 during the trip...then before would be the better option.
NachoMama
TIm
F-150
Synthetic blend is a waste of money. I forget what the minimum requirement is but, semi synthetic only has to be something like 10-20% synthetic to market it as semi-synthetic. Either got full dino or synthetic. I'll stick to the severe service oil drain owners manual recommendation using 100% synthetic and not Full Synthetic as there is a difference. ()
MSparks909
Miles
ENC
2014 Ford F-250
Full synthetic every 5K. Ecoboosts like clean oil. Plenty of real world info to back this up, it’s cheap insurance. 7500-10K changes on Ecoboosts isn’t wise but do what you want with your Bronco…
flip
Phil
IN
www.ruxerparts.com
Fords
3-5k or at least once a year. LOF is too cheap to do. Anyone doing the full synthetic thing….I have no issues with full syn. Ford has explicitly said the use of full syn does not relieve you from following their oil intervals. Don’t shoot the messenger here and I’m not going to debate or defend their position. Just putting it out there for consideration.
redone17
Cold Spring, NY
I was wondering why some were suggesting to change it so soon if the factory oil has such important components. I’ve never owned a brand new vehicle before.
