Fog lights wiring for Stroppe Edition?
ryanstroppe
Ryan
Raleigh, NC
2025 Bronco Stroppe Edition
Bought a Stroppe Edition a few weeks ago with the modular bumper. Not seeing any wiring for fog lights and the current switch definitely doesn't have the button. If I wanted fog lights in the regular part of the bumper, is it best to go through the aux board or what? Really trying to understand why they were omitted.
GnormalGnome
ee
PNW
2025 Ford Bronco
Broncos that come with the modular bumper do not get foglights. (except the Braptor).
Search "Modular bumper fog lights" and you will find many, many, many threads with lots and lots of options, including retrofitting oem wiring harness and headlight button for factory appearance.
Archerman907
Kyle
Idaho
2025 2DR Badlands SAS Desert Sand
You might have better luck than me, but I believe the wiring for the capped portion of the fog light wires were omitted for MY25.
I have front parking sensors and the modular bumper on a MY25 Badlands Every thread I have seen tells me where I should find these capped wires. Short of taking the entire bumper off, im pretty sure they were removed.
I would love to be proven wrong though. I would rather use pigtails and a retrofitted factory light switch than use aux switches.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
If you have a modular bumper there is no fog light switch. You just use your upfitters to turn them on and off
Check out our fog kits for the HD Modular bumper if you're looking for a QUALITY and STREET LEGAL fog kit: https://www.4x4truckleds.com/vehicle-specific/ford-bronco/2021-bronco/fog-lights/
GnormalGnome
ee
PNW
2025 Ford Bronco
Correct, for MY25 the fog light pigtails are not included from the factory. You can purchase just the pigtails, however, as well as the headlight switch with the fog light button. You'll need forscan, too, to enable the fog light circuit.
But unless you really want that factory look, it will be easier to just use a plug-n-play harness from a vendor (like 4x4truckleds) and wire to aux switches.
Arvidian
Andy
VA
2025 Bronco Badlands
Check out this post. It should give you the part numbers for the items you'll need to buy to get it to work; fog light switch and harness.
Jossman
1979 F150,2011 Mustang,2013 F150,2006 HD
Jossman
Archerman907
Kyle
Idaho
I cannot thank you enough for this link!
Jossman
The aux switch is the easiest + cleanest for Modular Bumper. Some fogs come with a switch for dash mounting But on my WildTrak went with #1 Aux switch.Went with Oracle Fogs which many people give bad reviews [mine have been problem free + there is a good You Tube Video to show install].But-Your Bronco,Your choice. The Oracles do come with a switch if that is what you want.
Ford Bronco Fog lights wiring for Stroppe Edition? IMG_0150
Jossman
Has anyone been stopped by Police when running the Oracle 3 lights per side fogs.I installed mine in 2022 when they said they were DOT compliant.They later came out + said if you just use 1 light per side on highway. Would not be that difficult to change options if needed,but as do not drive impaired [sober for 25 + years] will continue with 3 per side + take my chances.I have turned them on in the dark + walked about 500' away + they don't seem to be as bright as newer headlights in most vehicles anymore.
Ford Bronco Fog lights wiring for Stroppe Edition? Imag
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Josan why do you keep posting weird pictures after your posts and using a massive font? Also you have a few replies above where you just quoted numerous people and never wrote replies
Jossman
Sorry if that bothers you!!! I'm 80 years old + makes questions + answers much easier to read. As far as the weird pictures most people like them.If that bothers you don't read the posts!
