Floorboard Lights - Amber Replacement?
NativeTexan
Ben
McKinney, TX
2023 Ford Bronco Badlands
The floorboard lights have a blue-ish green-ish hue and I would like to replace them with amber lights to match the Badlands accents. All of my searches pull up high-glow aftermarket kits. Has anyone replaced these lights with different bulbs?
Tdecell
Trey
Clinton, MS
2004 F150, 2021 Outer Banks, 2022 Badlands
They aren't bulbs, they are LEDs. You would have to obtain amber ones and wire them in.
Alassise
Al
Or you can use amber film and cover them
helifino16
Ron
Mount Sinai, NY (Long Island)
I put blue film over my Fogs and still through as white. They only appear Blue when off.
Ford Bronco Floorboard Lights - Amber Replacement? Blue lights Fo
Alassise
Al
I did the same with lamin-x amber film for fogs and 20" light bar and they shine amber. On my interior aftermarket lights, I used left over pieces to make them amber and it worked very well. So, I think the ambience lighting can be done the same way and achieve the desired effect, just got to find where the led's are at.
ChrisB351
Shreveport, LA
Search the forum.. Been awhile since Ive seen it but someone swapped the color change ambient lights from an F150 and made them work. Probably your only option other than aftermarket.
CarmeloS
Carmelo
Central Jersey
Subbed. There was a guy who forscanned F150 MyColor into his bronco, but it felt like too much work and Idk any shops here in NJ that could do that.
I'm tired of ice blue, feels too cold and creepy
the poacher
john
Whistler
2010 ford ranger
Keep us posted if you do find a solution.
HolidayDog
Everglades
MT
24 Everglades
Everglades
I remember seeing a thread about someone here that did this. It was a programming or FORSCAN solution. I’ll find it.
Maybe?
Ford Bronco Floorboard Lights - Amber Replacement? 1729741707422-xx
