Flex Seal the MIC
En4cr
Western NC
23 Bronco Wildtrak
Noob here. Looking at a 2024 Wildtrak to get in the next month or so. I have seen threads on rhino lining the MIC top and other bed lining. Has anyone used the flex seal to coat the MIC top?
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
Not exactly what you are asking, but doing so will void any warranty. I think the vast majority of us are still under the 36 month warranty, so it’s more likely that you’ll see more coatings, paints, and textures applied as time goes by.
My December ‘23 build is at the dealer right now being evaluated for a MIC replacement under warranty.
Rick U
Is flex seal indicated for use as a top coat? I’m not sure it was designed for that purpose. I assume bed liners have some uv additives.
JT58Bronc
JT
Fl
2022 Bronco, 1987 Chevy Squarebody 4 X 4
Use 303 protectant. Works great on the MIC top. I do it every 3 months or so.
PWillette
Parrie
Maine
Pretty sure that flex seal stays soft when cured so probably not going to work. Several here on the forum have coated w/ bed liner though.
Rumbloki
Alton
ATX/PCB
ZR2, 1973 Mach 1
They used it to make a boat out of a screen door. It would seem they're pretty flexible with their indicated use.
UV resistant
Ford Bronco Flex Seal the MIC 1738952888289-8c
It won't hold up very long.
I did not do an automobile with it. But I tried lining some outdoor ponds with it.
Sure, it held water, for a while. After a year though it was starting to come up, and when I drained it to clean it and touch it up, almost all of it came back up. So I'd imagine a trip through the car wash would obliterate it after a few months.
KABQ
Aaron
Albuquerque, NM
Do you mean on the inside?
Felix808
SRV CA
If out of warranty & I have any issues, I would probably try something like resin and not the type out of your bowl :sneaky:
Perturbedmax
Max
PNW
23 bronco, 20 Silverado 3500, 15 Q5
I painted a cargo trailer with the white and grey colors 5 years ago and it's holding up really well. It does trap dirt though, looks good from far but far from good. I wouldn't be happy with it on my daily driver.
dpAtlanta
North of Atlanta
2024 Badlands & 2019 GT350
Wow... are you guys missing the boat literally. Have you forgot about Flex Seal?
Ford Bronco Flex Seal the MIC 1739317180505-vf
FLEX SEAL APPLICATION DISCLAIMER
This is 100% sarcasm............ but if you do it, please post videos/photos, we sure could use the laugh.
Dude1967
Billy
2025 Ford F150 Tremor
Probably get 15-20 years out of these. Maybe more if garage kept.
Insurance will make you replace every 15 to 20 years just like your home:)
helifino16
Ron
Mount Sinai, NY (Long Island)
I’m wondering how you got it to match the BL grill so well.
