Flat Towing W/ Capable Bumper
PhillyGuy
Tony
Chester County, PA
2014 F150 SuperCrew Platinum, 2018 BMW X3 M40i
For those equipped with the HD Modular Bumper.
Blue Ox Base Plate BX2692 (Replaced previous model BX2688)
Blue Ox 10k Avail tow bar BX7420 (2" receiver)
Blue Ox Towing Accessory kit BX88308
Stay-In-Play Duo Brake System perm. mount. Main control unit mounted under hood, switch mounted left rear inside.
Hope that helps!
Ford Bronco Flat Towing W/ Capable Bumper Bronco Flat tow
Ford Bronco Flat Towing W/ Capable Bumper Bronco Flat tow 2
Ford Bronco Flat Towing W/ Capable Bumper Bronco Flat tow 3
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
Thanks Tony!
Revnkevin
Cali
23 Bronco
Todd, are you using the recovery hooks or are you using the base plates? Those orange hooks with the D rings are factory?
Lil Pony SIP
Todd
Mississippi
The Black D-Ring Loops come with the Capable Bumper. I replaced those with the Orange D-RING plates from Ford. Then I bought the Tow Bar adapters from Curt.
wvabeer
Kenny
West Virginia
2022 F350, 2010 F150, 22 Badlands
Base plate plus a winch on the capable bumper
Ford Bronco Flat Towing W/ Capable Bumper IMG_20221221_205807727
BeardedRanger
IL :-(
Bronco Black Diamond; Ram Rebel 1500
Could you please share links to both the D-Ring plates from Ford and Curt tow bar adapters?
Bill K
Allen, TX
Hope that helps!
Hi again Tony. Finally acquired all of my parts, and will start the install next week (with the aid of my buddy's jack and garage :) ). Quick question, on the Bronco tail lighting for flat towing, do you know if your installer put in separate bulbs, or diodes in the factory wiring? My Blue Ox kit has both, and want to plan for the best option when I pull everything apart.
PhillyGuy
Tony
Chester County, PA
Don't know, but I will say that the brake lights appear to be as bright when towing versus not towing. Guessing, I would say the diodes.
Bill K
Allen, TX
Am leaning the diode way. Just not comfortable with drilling holes in the tail light assemblies, and I'm a pretty good wirer...
Bill K
Allen, TX
Thanks for the advice Tony. Just spent around 2 weeks on my buddy's lift. Completed the blue ox adapter installation, back light to front connector wiring, and while I was at it, put some fog lights in. I used some advice from the forum here and can turn on the fog lights with a factory switch I replaced.
I got a good deal on a Blue Ox Patriot manual install brake system, so I went with this. Can see how your permanent install unit would be very appealing though. Wish me luck as I move on to connecting to the RV next!
Bet this looks kind of familiar ;):
Ford Bronco Flat Towing W/ Capable Bumper Bill Flat Tow Front Pictur
PROBvictory
Cush
Fort Knox, KY
2022 Ford Bronco
your set up looks great, trying to do the same to my MY22 BL with the capable bumper; tried to do a quick sawp with the performance Rings but it looked like the steel trim retainer was getting in the way and the plastic trim wouldnt fit in with the top?
Did you have to snip/trim any of the Plate Facing plastic trim or steel trim mounts to get the Orange D ring plates to fit?
PROBvictory
Cush
Fort Knox, KY
2022 Ford Bronco
Tony, Got the stay and play duo setup you (and others) recommended, but before I go all "Edward Scissor hands" on the brake vacuum lines, I was hoping you could get me a picture of how you connected yours.
I saw they created a part/adapter that connects for some ford engines, did you use that or just splice directly into the Brake booster lines?
Thanks!
-CUSH
