Flame away - Removing the swaybar
FrostedNuts
Vermont, USA
Tons of Fun
Has anyone removed the swaybars on their Base Bronco, to add some more flex? I've put on my nomex suit, and have years of experience as a race and off road driver/ instructor, so I know all the reasons pro and con... But figured I asked before I went and did it. Obviously, not for everyday use- I should add. Strictly for trail work.
Thanks,
T
Frankie945
Frank
Louisville KY
Q50
I made my own swaybar disconnects and drove around with it disconnected a few weeks back. I wouldn’t recommend it for street use it had way more body roll taking turns. If your driving miss daisy you might be okay.
Ford Bronco Flame away - Removing the swaybar 79D13258-F18B-4FA5-A80D-D503A6D2B7B9
67BroncoG1
Ron
CA
'22 2D Squatch, '67 Bronco, '24 Grenadier -ordered
I completely removed my swaybar. Yes it has more body roll and yes it doesn't handle as well on canyon roads but it isn't a sports car and who is pushing it that hard on the pavement. I suppose that it could get interesting in a freeway emergency situation but It drives much much better off road. I have no interest in putting the bar back on but anyone removing it should be aware that it does change the handling and that could be a bad thing.
Murfman
Colorado Springs
2021 WildTrak, Cyber Orange soft top
Those are sweet!
Gofar
Doug
Carson Valley
21 Bronco 4dr base sas 2.7
Ditto
Felix808
SRV CA
While I have not done it on an IFS vehicle, I did it on my XJ. Removed both front & rear & drove appropriately with no issues.
YMMV :cool:
BAUS67
redneck
Central PA
Drove my Fox body around for years without the front sway bar. Plan on the same with my Bronc.😁
BroncoAZ
Mitch
I ditched both front and rear sway bars on my 87 Bronco on a long travel (17”F/16”R) coilover front/leaf rear suspension. It had some lean that was tamed with better shock valving, but was fine to drive for the 15 years I ran it that way. I would expect the Bronco to lean some but be fine.
kodiakisland
Arkansas
I have no problem with removing the sway bar, but the hitachi coilovers are pretty soft. I'd try it to see how it works for you, but the Bilsteins might be better for going swaybarless.
Bronkers
Ben
Las Vegas, NV
2022 2dr Bronco
Yes it is and I am
Also @Frankie945 can we get a write up or at least a parts list on your discos? Why isn't anyone selling these yet?!
BAUS67
redneck
Central PA
67BroncoG1
Ron
CA
Yes it is and I am
Enjoy that and I hope you keep the shiny side up. Personally I'll use sports cars for driving fast on canyon roads.
KPLOBX
Kristopher
Savannah GA
Jeep Wrangler TJ
I unbolted the links prior to going off road. Zip tied them back, easier than removing the whole thing
Did you unbolt the top or bottom?
