Flaky Camera
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
My 360 camera that's part of my passenger side mirror comes and goes. It'll work for days, and then be black for a few more. Likely I need a replacement camera, but I'm willing to pull some bits apart and troubleshoot on the idea that maybe a connector is simply loose. Has anyone else dug into where the connections points are in the wiring? I'm assuming there is a molex connector behind the mirror housing, but there has to be a downstream one as well I'd like to check the fitting.
rugedraw
Javier
Miami, FL
2021 Ford F150 Platinum FX4 EB/2023 Bronco Sport Badlands/1991 Mustang 5.0 coupe
If you don't have FORScan or a way to pull codes, PM me the VIN. I'll send you any codes the truck is reporting that are relevant to the issue. I can also send you any TSB's or SSM's that may pop up that may provide a clue to the problem.
j_marinelli
Spring Branch, TX.
I had similar issues with the front camera which ended up being an issue inside the camera itself and has worked find since getting it replaced.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
Swallace
Sean
N. Andover Ma
Toyota ,Gmc and Subaru
I had the same problem with the front camera going black. I gave it a couple of light taps and the problem went away and still has not returned. good Luck !!
Angelina
Angelina
Charlottesville, VA
2022 Bronco Sasquatch Luxe
I have the same problem with my front camera. Sometimes it's black and other times it works just fine. I have a '22 Badlands with 24k miles and the Ford dealership in Charlottesville wants $150 to look at it because "they can't be sure it's covered by the warranty." I'm confused on the definition of bumper to bumper. Oh - and they said it has to not be working at time of appt and I said but your a week out and it's intermittent. So if its working at the appt, I lose the $150 to look at it? This is my first Ford, but I've never heard of such terrible policies (that I hope are dealer specific). I don't know how to get the camera fixed with policies like this.
