Fixing Slide Out Tailgate Threads
JTBros
Long Island, New York
GR Corolla
I recently purchased a used slide out tailgate and the front right threads (closest to the tailgate hinges) are cross threaded. What’s the best tool to fix this? Most thread chaser kits only go up to 12 mm and this is a 13mm bolt.
Ford Bronco Fixing Slide Out Tailgate Threads IMG_4396
broadicustomworks
Hanging Rock, North Carolina
13mm is the bolt head size.
The thread size and pitch are not 13mm.
It is more than likely an M12 thread hole.
Guessing 1.75 pitch.
JTBros
JTBros
GR Corolla
Good to know thanks, I have some calipers to measure the body of the bolt which should be able to show the size thread hole, right?
Yeah, more or less. It's kind of hard to measure thread pitch with one, but it can be done.
If I recall, the mounting bolts in the tailgate area were all m8 1.25, and very common for m8 to have a 13mm head, but if this bolt is on the drawer itself... hard to say. Ford loves to use those m8 bolts all over though.
BudgetBronco
Tim
Pittsburgh, PA
www.youtube.com
JTBros
JTBros
GR Corolla
Winner winner, fit perfectly in that slot.
If you have a bolt that fits, take it to Home Depot or most any hardware store and in the aisle with hardware they will have one of these things on the wall, use it to find the right thread size and then buy a tap for just that size for like $5
https://www.homedepot.com/p/Saker-1...d-Nut-Identifier-Gauge-GJ64920-E001/332175461
Thanks for the idea, was helpful in figuring it out.
Ford Bronco Fixing Slide Out Tailgate Threads IMG_4398
JTBros
JTBros
GR Corolla
Update: put in the tap and used the die on the bolt and threads looked to be cleaned nicely. Unfortunately after threading it in the bolt is still spinning freely. Bit of a bummer and wondering if I just need a new bracket at this point.
