FIXED: Headlights turning on when switched off
Lifeliberty
Moonbeam👀
Columbus, OH
I wanted to bump this thread in case anyone else is having this problem.
I've had my Bronco just over a year and noticed the lights staying on, when in Auto Mode, a number of times and it is doing it more frequent.
The lights on chime will chime when you open the door. It acts like you left the lights on but the switch is in Auto.
I turn the switch to off and than back to Auto and all is good until it does it again.
I guess it's time to contact my dealer.
I hated to do it earlier because I made a bunch of Forscan changes and thought they might try to blame me.
Just get it from ruxer, it was $20+ shipping. Very easy to swap out. Easier than waiting at the dealer. If you have any questions I can help
Jsullivan
Jay
2018 Explorer, 2016 F350 Diesel, 2013 Explorer
Lifeliberty
Moonbeam👀
Columbus, OH
https://www.tascaparts.com/oem-parts/ford-headlight-switch-m2dz11654cc
Thank you.
This is the switch I found so far but it also has a button fort rear fog lamps which I don't have.
If you can supply me with the ruxer part # that worked for you I would appreciate it.
Thanks,
contact/ direct msg @flip on here with your vin and he will walk you how to order. With the vin he can confirm the correct current part.
I've bought all my factory bronco parts from Ruxer, service has been awesome
My part was
M2DZ-11654-GC​
Switch Assembly Headlamps​
https://www.ruxerparts.com/oem-parts/ford-headlamp-switch-m2dz11654gc
Jsullivan
Jay
TNcoupe
Decatur,TN
2022 Badlands, 2023 BD, 1969 F100, 1955 T Bird
Anybody got the part number for the headlight switch with fog lights? I have my Baja Design S4s wired into my fog light pushbutton.
TNcoupe
Decatur,TN
Replaced mine today. Lets see how it goes.
RaceRedOBX
Brock
Louisiana
2017 F-150
My headlights started coming on by themselves today.... Guess ill mention that when I drop it at the dealer in a few days for some other repairs..... Hopefully it is just a bad switch.
PSUTE
Western Maryland
Sierra
May want to let them know so they have the part on hand...
Some 2021-2022 Bronco vehicles may exhibit a condition of intermittent headlamp operation while the vehicle is OFF and have diagnostic trouble code (DTC) B1533 stored in the body control module (BCM). This may be due to the internal logic within the headlamp switch. To correct this condition, replace the headlamp switch (service base PN: 11654). Refer Workshop Manual, Section 417-01.
the part number is:
M2DZ-11654-AC or M2DZ*11654*GC?
switch assembly
bdezmo
2008 Chevy Dually
I'm waiting on my switch to come in...been on order over a week. It's definitely a warranty item. I brought the paperwork from the beginning of this post and they didn't even hesitate.
Imsomaha
Omaha
2023 ford bronco
23 bd bronco does the same thing. Bought two switches and still happening. Took into dealer, they said i have too many add ons (only trail marker lights) which have been on for two years. Everything unplugged and still happening. Next step change battery, then flash bcm and maybe replace bcm. Any other suggestions?
