Sluggish when turning
ChadRockPSU
Chad
Jeep Grand Cherokee
HI all, I have had my '22 OBX since April (9k miles)and recently have noticed that when attempting to accelerate through turns that it feels extremely sluggish. I don't have any rubbing or sounds associated with the situation, nor is it leaking any fluids, but something doesn't feel right. I have zero mods on the vehicle, it is 100% stock, and all of my driving is city travel with no off road. Figured I would inquire with you guys prior to taking it to my dealer. TIA
helifino16
Ron
Mount Sinai, NY (Long Island)
I guess it probably goes without saying, but you also should not have the locking differential (front or rear) engaged for on the road driving. I checked and they can be engaged in several G.O.A.T. modes (Normal, Eco, Sport, Slippery & Baha), but only to 25MPH in all but Baja mode.
Like the previous entry suggests, it really sounds like you're in one of the 4WD modes. (That's how it will act on hard surfaces in 4WD).
If you're in 2H with no Diff locks, then there's probably something wrong and it should be checked (i.e. it MAY be in 4WD or have a Diff Locked and not show it).
Silver-Bolt
Bill
Eureka, MT
Is it only when turning? No issues going straight? Are you building boost?
ChadRockPSU
ChadRockPSU
Chad
Jeep Grand Cherokee
Thanks for your take on this.
To the best of my knowledge I am absolutely not in 4WD, nor am I in any GOAT mode other than "Normal". As far as locking Diffs go, unless it is engaging them on its own, I have not done so. I guess she needs to go to the shop. Unfortunately I see this as a situation where my dealer calls me back with the response of "The technician was not able to duplicate what you are experiencing!".
ChadRockPSU
ChadRockPSU
Chad
Jeep Grand Cherokee
If you have lockers on that is the problem
I have an OBX with Mid Package and do not have the manual locking diff capability, so if they are locking while in 2H then there is something going on with the computer. Is there a sure fire way of knowing if they are in fact locking. I apologize if this is a dumb question.
Silver-Bolt
Bill
Eureka, MT
Do any of your brake rotors look discolored from heat? Sounds like possibly your brakes are dragging.
IDyeti
SPAM
Boise, Idaho
21 Bronco BD
Jack up the rear, rotate a tire, if both tires move its locked, if one moves its an open diff. If neither move the parking break is on.
ChadRockPSU
ChadRockPSU
Chad
Jeep Grand Cherokee
I don't see any discoloration or detectable grooves in my rotors. However; It is interesting that the brakes may be the culprit here. Three months ago the dealership replaced all four calipers and pads due to a system leak.
AcenTitus
Peter
MO
This popped up when I searched for my recent gremlin. I noticed the same issue when pulling into my garage. I’d made many turns on my 15 minute drive before then with no issue. I wound up reversing and turning the bronco off and on again to get in. The next day I left and found the same issue but worse. I pulled over quickly after trying to make a third left turn and knowing something was very wrong. A GOAT mode had activated and I was in 4H. I did not do that. @Ford any thoughts about this Ghost in the machine? (Goats in the machine?)
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Hi Peter. Can you send us a DM with your VIN and dealership info? I can look into this for you.
gwbigdog
Guy
OVERGAARD, AZ
jeep
I noticed that solid driving in mountain turns, my truck will sence the " g" forces and slow down and accelerstevon it's own. Im using cruise control.
