Fishing Rod holder
MVBB
Dan
MA
2022 Big Bend
I used the trailrax mount and mounted a rod holder to it.
It was like.... really easy.
Plus it looks like I have cannons mounted to my hood.
Any better rod holder mods?
Ford Bronco Fishing Rod holder 7A30A77C-A45C-4593-BE25-22914AFA08CA
Ford Bronco Fishing Rod holder D783E6C6-51B8-4AD3-B6B4-1876C4CE83BF
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Great idea!
I bet you could mount a couple t-shirt cannons that they use at sports events to those… :unsure:
BR0NCO
Randy
Mass
Jeep Audi
You on Martha’s Vineyard? My stepsons grandparents live there and he goes fly fishing there in the summers
PrincipalD
Ryan
Sioux City, IA
Expedition, Bronco
This looks too easy! Is there a reason to do this and not place them inside the Bronco in some sort of roof mount? I have a soft top coming, so there is an obvious reason not to. Just wondering if there is an internal option you have or have seen. I would hate for someone to swipe my Zebco 33 from Walmart… 😂
level3looper
New York
MVBB
MVBB
Dan
MA
2022 Big Bend
I would carry four rods, but only for my rods ;)
@MVBB , can two trailmax mounts be attached opposing on the same trail site? That could get four rods up.
That is what I'm working on now...
All that is needed a small flat metal bar with 2 holes. 1 hole attaches to the mount (and a rod holder), the 2nd hole for a 2nd holder. Could even go 4 wide. The problem with the trailsight mounts is that they have to mount on the outside - otherwise the hood hits it when you try to open it.
redone17
Cold Spring, NY
2021 Bronco, 2020 Ranger
I gotta say…for popping from spot to spot - this is a great solution. Adding a quick release knob under… Now I’m kicking myself for not jumping on the introductory price for the mounts.
MVBB
MVBB
Dan
MA
2022 Big Bend
yep! Fishin season is just around the corner too.
MVBB
MVBB
Dan
MA
2022 Big Bend
Not much room and I worry about the hooks in the soft top. Top off, you could mount a roof rack. Haven't taken the top off yet
MVBB
MVBB
Dan
MA
2022 Big Bend
I have the holder held on by a single nut and bolt. I keep the allen wrench in the car and can pop the holder on/off quickly. The trailsight bracket stays on permanent
redone17
Cold Spring, NY
I dig it.
OB121
Bay Shore
2019 Expedition 2021 Bronco Outerbanks Sasquatch
Nice, if you put a bar across maybe you can use quick release pins to get the hood open if you had to.. I have my air compressor in the engine bay so I went with a front mounted rack.
