Fishing Rod Holders
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
If you’re a fisherman looking for a place to mount your fishing poles, look no further! Designed here on Long Island, NY (surf fishing capital of the world) this mounting system provides a simple and elegant solution to a common problem. That problem… Where do you mount your fishing poles on the Bronco?
Utilizing the existing mounting points on the front of the truck our stainless steel bracket system provides a secure and stable system to support 1 or 2 rods (per side). Each holder is designed to safely and securely hold your fishing pole without damaging it. The angle of the mounting system allows you to transport long fishing rods without the fear of snagging an over-pass or electrical line. The rods sit at an angle hovering over the roof line to ensure your rod does not hit the roof during transport.
Simply bolt on the system, slide in your fishing pole and head to your favorite fishing spot.
FEATURES
  • .125″ #304 Stainless Steel Bracket (Made in the USA)
  • Nylon/Acrylonitrile Butadiene Styrene Fishing Pole Holder
  • Powder Coated Black Finish
  • Designed & Assembled in the USA
INCLUDES
  • 1x KR Off-Road Brackets
  • 1x or 2x Fishing Pole Holders
  • Mounting Hardware
  • Instructions
FITMENT
  • 2021+ Ford Bronco
WARRANTY
  • Lifetime Warranty for the original owner.
For more information and to purchase: https://kroffroad.com/product/40-200x/
SINGLE
SKU: 40-2001
The Single Kit allows you to install the fishing rod holder on either the driver side or passenger side.
Ford Bronco Fishing Rod Holders 40-2001_2-300x300
Ford Bronco Fishing Rod Holders 40-2001_3-300x300
If you have two (2) Single Kits you can mount them back to back as well, allowing for 2 rods/reels to be mounted on each side. This will prohibit the hood from opening with the system installed (you’ll need to unbolt it if you need to open the hood). It’s recommended to order our Double Kit if you need to mount two (2) rods/reels while having the ability to open your hood.
Ford Bronco Fishing Rod Holders 40-2002_2-300x300
Ford Bronco Fishing Rod Holders 40-2002_3-300x300
DOUBLE
SKU: 40-2003D & 40-2003P
The Double Rod Holder Kit includes two (2) rod holders (and 1 bracket) and installs on either the driver or passenger side (each side is specific and cannot be swapped). With the Double Rod Holder Kit you can open your hood with 2 fishing rods installed. If you install two of these kits, that will allow you to hold up to 4 fishing rods/poles total while STILL allowing the hood to be completely opened.
Ford Bronco Fishing Rod Holders 40-2003P_2-300x300
Ford Bronco Fishing Rod Holders 40-2003P_3-300x300
Ford Bronco Fishing Rod Holders 40-2001_5
Ford Bronco Fishing Rod Holders 40-2001_6
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Share a photo of your rig on the beach fishing! Here's one of our customers
Ford Bronco Fishing Rod Holders Rod Holder8
mjp2
NJ
2021 Cyber Yellorange Bronco Badlands
Pic just before we rolled out to head home for the day. Those rod holders are fantastic and make packing for the beach trips so much easier.
Ford Bronco Fishing Rod Holders 1728322916436-0q
Being able to pop the hood with them installed is such a key feature.
Ford Bronco Fishing Rod Holders 1728322999025-r5
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Looks good!
